Question about JVC Televison & Video
JVC HD70FH97 RPTV My screen is dim even after replacing lamp. How do I access the mirrors to clean them? Can I use QTip with alcohol on mirrors? Can I use shop vac to clean other interior areas?
Posted by Lord Les on
    Top Expert:
  • JVC Master
  • 76,573 Answers
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
https://elektrotricks.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Feb 28, 2021
5 Related Answers
Anonymous
  • 668 Answers
SOURCE: replaced wd-62525 lamp, picture dim
Cleaning the mirrors will not increase the brightness much. I would double check the lamp setting in the Menu and also the setting of the picture and brightness settings. Many times these are adjustable independently for different inputs. Besides this, I would look at the Ballast and or the Power Supply to cause the problem. I would recommend a professional to look at it if it is not correctable from the Main Menu of the set.
Hope this helps,
Skyassoc
Posted on Jul 17, 2009
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: ghostly vertical lines
you have done said it vertical lines then you will have to take your tv to a tech for repairs.good luck.
Posted on May 14, 2007
Anonymous
SOURCE: Mitsubishi WD-62527 replacement lamp install and brightness low
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Posted on Mar 20, 2009
Anonymous
  • 13 Answers
SOURCE: interior lights, power mirrors and cargo lamp doesn't work
check your fuse.
Posted on May 24, 2009
honeymokey
honeymokey
  • 3113 Answers
SOURCE: Mirror no longer clear, discolored
A used one?
Posted on Jun 05, 2009
I changed the lamp and tv colors are opaque, what I can do to fix this problem
Clean the bulb and make sure you did not touch it with bare hands or you may the wrong lamp so check that also
Oct 14, 2014 | JVC SELECT HD56G786 Rear Projection...
JVC HD52Z575 hdtv - replace lamp but screen still dim
A ballast is possible but was the Lamp you replaced JVC or a generic lamp from the internet?
Mar 12, 2012 | Televison & Video
JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Jan 25, 2009 | JVC HD-56G886 56" Rear Projection HDTV
I just replaced the lamp on my Mitsubishi WD-62327 picture is dim
TAKE THE FRONT SPEAKER PANEL OFF AND YOU WILL SEE TWO SCREWS ON THE LEFT AND RIGHT TOP CORNERS THAT HOLD THE TABS FOR THE SCREEN LOOSEN THEM THEN GO BEHIND THE TV AND REMOVE THE SCREWS AROUND THE PARIMETER OF THE BACK OF THE SCREEN 10 TOTAL THEN REMOVE THE FRONT CENTER PANEL 4 SCREWS AND UNPLUG THE SCREEN EASY TO SEE WHICH ONE THEN JUST LIFT THE SREEN STRAIT UP ONCED REMOVED YOU CAN CLEAN BOTH MIRRORS DONT USE CHEMICAL CLEANERS JUST A SOFT RAG HOPE THIS HELPS
Jan 23, 2009 | Mitsubishi WD-62327 62" Rear Projection...
The panel on my laserjet 3380 says scanner erroe power off power
You need to clean the small mirror film. Repeatedly turning on and off the printer will move the scanner head to the left. When it makes it to it's final position remove the screw and using a qtip gently wipe the thin mirror film next to the light bulb. This will clean the dust that is causing the error. some say use alcohol on the qtip i never used it. Once it's clean the scanner will return to it's original position and resume function. return side glass and screw, and you should not have that error until it's once again dirty.
Jan 17, 2009 | HP LaserJet 3380 All-In-One Printer
Dec 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Gray spots on screen on a JVC HDILA model HD 56G 787
The gray spots are caused by dust on your lens, very easy to clean.
Power down the TV.
If you open the right side access panel (right side as you are looking at the front of the TV) you can see it in the middle, it's not very big. Using a scratch/lint free cloth, gently wipe off the lens or use a vacuum to **** up the dust being careful not to actually touch the lens.
Replace the access panel and enjoy your spot free screen.
Sep 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
JVC Sirius KD-LH300 CD Player
You need to open your stereo for manually clean the laser lens.With cotton Qtip wet in isoprophilic alcohol clean the laser lens then with the dry part of the qtip clean the residues of the alcohol.The lens look like an fish eye.
Aug 06, 2008 | JVC Sirius KD-LH300 CD Player
How can I clean the mirrors on this tv?
to clean the mirrors you must remove the screen first there are several screws in the back to remove the screen. then there is a mirror shaped like a polligon clean this with a dry cloth do not use a paper towel. soft colth must be used on any optical surface. then clean the optical engine lens in the same manner. them the large mirror in the back. remeber if you leave a defect on any of these surfaces it will be amplified by the screen. this system relies on a lamp to provide bright picture so replace that as well. this should be a part of your anual cleaning agreement of the after market warranty you purchased assuming you bought one. dim picture = lamp, fuzzy, dim, dull picture = dust
Feb 10, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
