Question about Onkyo Audio Players & Recorders
SOURCE: can you tell the wattage of the onkyo tx 905
140 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven from 20 Hz to 20 kHz, with a
maximum total harmonic distortion of 0.05% (FTC)
170 watts minimum continuous power per channel, 8 ohm
loads, 2 channels driven at 1 kHz, with a maximum total
harmonic distortion of 0.7% (FTC)
180 watts minimum continuous power per channel, 6 ohm
harmonic distortion of 0.1% (FTC)
Posted on Oct 22, 2009
SOURCE: Hi! I have onkyo TX-SR308 and i surround problem.
You need to tell it you have surround speakers. Page 30.
The manual is available here...
http://www.onkyousa.com/model.cfm?m=TX-SR308&class=Receiver&p=d
Posted on Apr 28, 2010
Testimonial: "Thanks"
SOURCE: ONKYO TX NR 709 OPERATES WITH 120V FOR US BUT I
If your Onkyo does not have a voltage button (usually on the backside close to the power supply) where you can shift in between the needed voltage (typically from 110 - 230 voltage) you need to purchase a Voltage converter.
You need one that is able to convert from 110 volt and up to 220 volt. (Step up)
Here is a site which can inspire you to choose the right Voltage converter :
http://www.110220volts.com/Power/Voltage+Converters.html
Regards
Posted on Sep 27, 2011
SOURCE: Hi, I need help order Onkyo part# BCCLA-1575 for my receiver?
Very poor parts support. They will, flat out, refuse to sell any parts directly to consumers. Stating safety concerns...yeah, right.
Onkyo does not care if their products occupy landfills. They just want the profits.
I have tried just about every Onkyo authorized distributor, and NO ONE will sell me Onkyo parts!
I agree, don't buy Oinkyo
Posted on Sep 09, 2015
