Question about Samsung Audio Players & Recorders
Samsung HT-C450 dvd with home theater, is prot mode. Please help me
Posted by Saji on
Relax
    Top Expert:
  • Samsung Master
  • 33,905 Answers
This is usually caused by a damaged audio output stage.
Time for a specialized repair.
Posted on Feb 26, 2021
When I turn my system on, it waits 5 seconds, says "PROT" then shuts itself off.
There could be a short circuit in one of the speakers. This would cause high current flow thru the amplifier and result in self-protect. Disconnect all speakers from the unit and try powering up again. If there is no PROT, then reconnect speakers one by one until fault found or all speakers are reconnected.
Oct 04, 2015 | Samsung Ht- C550 5.1 Channel 1000 Watt...
Samsung dvd player display says "protection" . Wont turn on.
Swtch off and disconnect and reconnect all the wiring especially speaker wires.
Also try resetting as per manual.
If that doesn't work then could be capacitor blown on motherboard.
Aug 06, 2014 | Samsung Ht-c650w 5.1 Home Theater System -...
Manual for samsung dvd home theater system model HT-Q40
Your Quick Guide and User Manual for the Samsung HT-Q40T/XAA may be downloaded here.
Jan 25, 2012 | Audio Players & Recorders
I have a samsung HT-Z120 it show a PROT error
This error means that you are trying to play a region-protected disc that is not in the same region as your player.
It is possible to "hack" the region on your DVD player by following these instructions:
http://www.videohelp.com/dvdhacks/samsung-ht-z120/10244
Please rate my answer.
Thanks,
Chris
Mar 05, 2011 | Samsung HTP-1200 System
When i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
PROT means that the AMP is protecting itself from damage due to bad or incorrect wiring or damaged and or incorrect speakers. Check your wiring and speakers.
If you find no problem then, DISCONNECT YOUR SYSTEM FROM THE POWER, disconnect your speaker wires...all of them, then reconnect the power ONLY, turn on the system and see if it still says PROT. If it does then your amp is damaged.
Feb 20, 2011 | Samsung HTC550 Theater System
Whatb does it mean when the PROT comes on and then shuts off the dvd player
hello, prot mean protect the output transistor may have blown or a capacitor has poped or swelled up or the just could be a case of a dry joint
regards
shaun
Nov 22, 2010 | Samsung HT-X50 System
Samsung ht c550, enciende, saluda, lee y aparece el mensaje PROT y se apaga.
when i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
Oct 11, 2010 | Samsung HTC550 Theater System
When I put on my DVD player, it says "hello, DVD, LOAD, PROT" and turns off...
I assume "PROT" means some sort of protection mode. I would check to see if any of your speaker wires are crossed at the speakers or the receiver. If not you may have shorted something internal.
Mar 18, 2010 | Samsung HT-WP38 System
HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Dec 29, 2009 | Samsung HT-DB120 System
Top Samsung Audio Players & Recorders Experts
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
