Question about Electronics - Others
My pro steam press shuts on and off during operation and beeps constantly until it shuts off sometimes it comes right back on sometimes I have to switch it off and back on can someone explain
Posted by Scott sigala on
ray gallant
    Top Expert:
  • 71,688 Answers
Moises Nepomuceno Apr 04, 2021
I can help youhttps://premium.chat/mdtvittechsupport
Posted on Apr 06, 2021
5 Related Answers
snakehead
Henry Thomas
  • 1074 Answers
SOURCE: Euro pro steam iron model G6118H
the preasure tank inside the iron could have a hole or the holes at the bottom of the iron are clogged up and needs to be cleaned.good luck
Posted on Apr 18, 2007
Anonymous
  • 75 Answers
SOURCE: Constant beeping
insert the paper first to your paper loader, as per my knoledge it beeps only in roller feeder is empty,make sure your lever selection is corect ,
if not- refer thr manual ,you can find the soluton
it is basically from paper loading problem
all the best
Posted on Mar 06, 2008
Anonymous
  • 65 Answers
SOURCE: tefal steam generater pro express turbo
Most of the time the electro mechanism release the steam still open and not able to returning in closing position.Try to cclick quite few time to excite the mechanism and some times work.Also can be the micro switch defective.
Good Luck
Posted on Jun 21, 2008
Anonymous
SOURCE: Tefal Pro Express - Constant Steam
Found this on another site and just tried it. Put 50/50 water and vinegar in the tank and leave it to go through on the constant steam. Give it about 5 minutes then try the button. Mine gave an extra spurt of steam at this point but still continued giving steam out all the time. I refilled with the water vinegar mix and just kept pressing the steam button and letting it go through. Eventually it fixed it and the constant steam stopped. Something to do with a piece of limescale blocking the solenoid but that's all Greek to me! Hope this helps. Kind regards.
Posted on Feb 04, 2009
Anonymous
  • 624 Answers
SOURCE: receiver randomly shuts off during play
This is the "Protect" mode. It is either a bad speaker, or not good ventilation, or a channel going out in the receiver. Please provide more details about the problem so I can help you better. How long is it playing before it shuts off, does it shut off even if the volume is low? Disconnect the speakers form the receiver and then turn it on and let it play without speakers, if it still shuts off then the problem is not the speakers. More information is needed to better diagnose this problem.
Posted on Feb 06, 2009
Error occurred during start operation(80010017)
Press and hold power the unit will come on beep twice then shut off. Next press and hold the power until the unit beeps again then release it. That should take you to the recovery menu. Then you can format your Playstation. Also you can put a new hard drive in to format in instead.
May 20, 2013 | Sony Ps3 160 Gb Slim Charcoal Black Game...
Reset a playstation 3 back to factory
With Playstation off from back switch. A) Turn on from back. B) Press and hold the front power button until you hear a set of two beeps. (You first will hear 1 beep)Beep! >>>>continue holding power button until your hear a set of (2) quick beeps( beebeep!!). You should now be now in service menu. (Note) If the after holding the button down it happens to shut off. Repeat step B and it will work. It does this sometimes. Be careful you are now in the service menu this gives you options like formatting your hard drive that the System menu in normal operating mode doesnt. Hope this helps.
5= 6= 7=
Oct 07, 2011 | Sony Playstation 3 (PS3) Console
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
Sep 01, 2011 | Amana AOCS3040SS Electric Single Oven
My UPS does not start
I'm guessing that during the power outage, the ups battery completely discharged. Now it will take about 14-15hrs to recharge it.It will not support any devices until it is fully charged. Remove all load devices and let the battery restore to full charge before re-connecting the devices. If the battery does not recover, it needs to be replaced.
Apr 16, 2010 | APC MasterSwitch Power Receptacle - Power...
When pressing steam does not come out. need to replace (part) PUM
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101//
Feb 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I do not have steam coming out of the mop i have it plugged in
i would take it back,IF YOU R FILLING IT WITH WATER AND ITS NOT PRODUCING STEAM,ITS BROKEN
Jan 27, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Any schematics available for a APC Back-UPS Pro 650PNP? I installed a new battery (yes correct polarity) and smelled a little smoke. It was unplugged during the battery swap. I took the cover off but...
hi, i don't have the schematic but, i think if you connected the batteries okay and had switched off the machine then it should work. when switching on there are two sounds that come, first its a beep, if you release the ON SWITCH the UPS will just do a self test then shutdown. to switch ON the UPS completely don't release the on button until you hear a second beep, if you release the ON switch when this beep is on, then the UPS will be ON completely.
Nov 09, 2009 | APC Back-UPS Pro 650 UPS System
Jan 04, 2009 | Tefal Ultraglide 1549 Iron
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Starting computer
Your power and data system need inspection inside the MoBo. Hardware problems produce warning beeps, especially RAM and VIDEO. Check these first to make sure they are in slots.
Does it show anything on the screen while it's beeping??????
Please provide more information and come back
Feb 19, 2008 | MSI K8N Neo4-F Motherboard
Electronics - Others Logo
Top Electronics - Others Experts
Tom Chichester
ray gallant
Are you an Electronics - Other Expert? Answer questions, earn points and help others
