Question about Samsung Refrigerators
Working on a Samsung fridge rs2533sw freezer or fridge is not getting cold Compressor is kicking in fine replaced the fan in freezer side still temps are 63/78
Posted by Lamont Clayton on
David Spradling
    Top Expert:
  • Samsung Master
  • 12,026 Answers
Try running with thermistor disconnected if ok replace if no bad cooling unit
Posted on Feb 27, 2021
5 Related Answers
Anonymous
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
Anonymous
  • 700 Answers
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Posted on Dec 24, 2008
Bruce Denton
  • 273 Answers
SOURCE: model #rs2556sh. the freezer is
the evaporator may be froze over with ice..remove this rear panel and if ice or frost is covering evap..use a hair dryer to defrost the coils. this will give you temp service...there still will be the problem that caused it to freeze up and will continue until repaired. its possible the defrost thermostat is bad or the heater or even the defrost control....Bruce Denton
Posted on Jan 09, 2011
Anonymous
  • 76 Answers
SOURCE: just moved into new house.
The compressor probably needs re-gasing. You will need a refrigeration engineer.
Good luck
Posted on Aug 05, 2011
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: fridge on all the time, freezer temp 25 fridge temp 45, iced over evaporator coil, freezer and compressor fan both working and compressor operating
Better to change both parts=>2188174 Defrost Heater Assembly and the 2188824 Defrost Thermostat
Thanks John Tripp Appliance 911
Posted on Jan 24, 2014
Testimonial: "thanks John, I think you're right but Ive realized there is a simple test with the ohm meter while the heater assembly is in situ to determine whether its still good. I see the replacement of that could be a real pain in the a** !"
Samsung rs2630sh not cooling or freezing
If it has fan to deliver cold air, and it is not working, cold air is stuck on the begining. So your fan could be dead. And I suppose, that compressor is running all the time. Even compressor could stert freezing if fan does not deliver cold air in fridge. The other option is, that there is not enough gas in the compressor. In this case compressor vould not be freezing, but line, going out of compressor has to be hot, if it is not, there is no gas.
Dec 02, 2017 | Samsung RS2630WW Side by Side Refrigerator
SAMSUNG RS2534WW CONDENSOR FAN NOT WORKING
Was the motherboard replaced because the temp was too high? May be the condenser fan was at fault all the time. Check you have power at the fan. If you have, replace the fan. If you have not, take a live from the compressor to the fan. This will bypass any hp or fan speed control switch and run the condenser fan with the compressor.
Apr 20, 2012 | Samsung RS2630SH Side by Side Refrigerator
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
Samsung RS2533SW refrigerator is not cooling, freezer is working well. how to fix the problem. don't say unplug, I already tried many times for unplug for 15 seconds, 2 minutes, 2 hrs and overnight. The...
If your seals are good on the door and the fridge side is set for a mid range temp ck and make sure the fan is running in the fzr side. The fridge side steals cold from the freezer by directing air from the fzr to the fridge. Also make sure the fzr does not have an ice block in it the back will be frosted up and if you took the back shell off you would see the cooling coils frosted up real bad or even iced if you find this your refrigerator is going to stop working soon. The suspect parts are the defrost timer the heating element in the freezer located with the cooling coils and the defrost limit this is a nickle size disc with one wire running to the end of the heating element it kicks the element on and off to keep it from overheating the fzr. The defrost timer is usually located in the fridge side under the top or backside plastic it will have a slot in it that a flatblade screwdriver will fit it and you can turn it with audible clicks It kicks the heating element in for a few minutes each day if it quits it will not advance. Hope this helps all of the parts can be purchased and installed by the home owner good luck and remember to unplugg before delving into the elect parts.
Aug 16, 2010 | Samsung 26.0 Cu. Ft. Side-by-Side...
Freezer won't stay consistently cold
replace temp sensors in fridge and freezer (easier to do together) should work fine...
Feb 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
My fridge not cold but freezer working fine
there is a shaft from freezer to fridge that the cold air travels. make sure that is unblocked. also make sure the fan is working. then see if the freezer coils are iced up (this restricts air flow). if they are, unplug it, empty the fridge and freezer, defrost the coils, dry it out, plug it in and turn it on (not high). once it reaches the temp and the compressor stops, fill the fridge again.
Jul 30, 2009 | Samsung Refrigerators
Samsung fridge freezer
Jul 30, 2009 | Samsung RB215LASH
Refrigerator Not Getting Cold--HotPoint HSS22IFMD WW
Take a look to the thermostat first!
Jun 24, 2009 | Refrigerators
Samsung rs2533sw fridge not cooling
Dec 20, 2008 | Samsung RS2534 Side by Side Refrigerator
Refrigerators Logo
Top Samsung Refrigerators Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
