Question about ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA 775-SIS 672 968 VGA FETH (610839154845) Motherboard
Posted on Feb 28, 2021
SOURCE: P5S800-VM multimedia audio controller driver
Hi Mairaj, please click the link posted below. This is Asus download site for your board P5S800-VM. Suggest you bookmark this page in case you need another driver.
http://support.asus.com/download/download.aspx?modelname=P5S800-VM&SLanguage=en-us
Creat a folder on your desktop & name it Audio.
Click the + sign next to Audio. If you are using Win XP home or Pro download,
Realtek ALC655 AC''97 Audio Driver V3.66 for Windows 98/ME/2000/XP(WHQL)/2003.
File size 24.17MB. Save file 32b366.zip in the folder you created.
The file 32b366.zip must be uncompressed before you can install it. If you do not have winzip please download this program for free from the link below. Install winzip into your PC.
http://www.download.com/WinZip/3000-2250_4-10003164.html?tag=pop.software
Once the file 32b366.zip has been uncompressed you can install the software.
If you have more questions feel free to ask.
Good Luck & have a Great Weekend!
Mike
Posted on Mar 22, 2008
SOURCE: ASUS motherboard driver
HOLA
YO TUVE EL MISMO PROBLEMA
SOLUCIóN:
VIDEO DRIVER:
INTEL GRAPHICS 82865G
ESTE ES EL MALDITO DRIVER DE VIDEO DE ESTA MOTHER
http://www.intel.com/support/chipsets/sb/CS-009241.htm
LO CONSEGUí POR LA CARPETA DE DRIVERS UBICADA EN WINDOWS XP COLUSSUS UE DVD, MI PROBLEMA ES CON EL AUDIO, AL INSTALARLO SE ME BLOQUEA LA PC.
SALUDOS
ING. RAúL BARRERA
[email protected]
Posted on Mar 19, 2009
SOURCE: audio driver for asus p5sd2-vm mbd os winxp sp3
find a way to remove servicepack 3 then try again.
if it works then re-upgrade to sp3
Posted on May 22, 2009
SOURCE: ASUS P5SD2-VM PLZ ME DOWNLOADS SOFTWARE
rizwan16 -
Go here: http://support.asus.com/download/download.aspx?SLanguage=en-us
Fill out these boxes as in this screencap (Motherboard, Socket 775, P5SD2-VM):
Click "Search", put in your operating system when prompted (Win XP?).
The page that comes up will have all the downloads for your motherboard.
Thanks,
videoman7
Posted on Aug 07, 2009
SOURCE: how to free download audio driver for asus
You can download the required drivers from:
http://www.asus.com/product.aspx?P_ID=napibCwKrjGDncvA&content=download
On the page which opens, select your operating system to download the appropriate drivers.
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Posted on Sep 24, 2009
no OS told. at all, windows,chrome,linux,?
asus.com
ever heard of them
all drivers they support for this MOBO is there.
they do not support w10 on that old dog mobo.
asus.com ended all support now. for
old mobo.
no P5 mobo support there at all
why mess with so old mobo? w10 does not support it due to asus. ended support.
that is a fact.
V2 mobo released in 2007, 14 years ago.
V1, IDK but older.
the lost manual is here
https://www.manualslib.com/manual/449459...
V2 mobo hardware version stamped there.
the endless story (2007 PC)
installed w10 to relic PC
and fails.
it gets worse
SIS chip there are not supported by SIS or Asus. (same goes for VIA chips (junk)failed.
and
Realtek
ALC 662 6-channel High Definition
not supported now, either .
I have 2007 intel mobo that runs core2, quad
w10 64 bit , one of the very few that old that does run W10-64bit OS.
I tested vast old mobo to learn, that.
its future is zero.
https://www.asus.com/support/
the page is there for your mobo
P5SD2-VM
with the dash, or it gets lost finding it.
https://www.asus.com/supportonly/P5SD2-V...
shows w8 but is a lie.
you must select all OS there and see what is supported and what not, sound is your
first problem(there will be more)
Visa 32 and 64 but is the last OS supported
for sure.
Version 6.0.1.5473
2007/10/19 49.92 MBytes
Realtek Audio Driver V6.0.1.5473 for Windows Vista & 64bit Vista(WHQL).
this facts is because SIS and Realtek ended
sopport long long ago , 2007 ended
asus web site search show no hits for P5
one has to drill and drill to find it.
found.
this very old mobo is not supported
by maker for new OS, nor does Microsoft
nor does many chip makers used on this old mobo. nor SIS !
