Canon ImageRunner 2270 | IR2270 | Logo
Duke Hans Posted on Feb 25, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Canon ir2270 is showing replace cartridge toner. Can this cartridge toner be repaired?
ray gallant
Level 3:
Top Expert:
  • Canon Master 74,163 Answers
  • Posted on Apr 17, 2021
ray gallant
Canon Master
Level 3:
Top Expert:
Answers
74163
Questions
0
Helped
657169
Points
561709
Not a good idea to even try many makers have chipped the machines to only accept OEM
5 Related Answers
A
Anonymous
  • Posted on Mar 31, 2009
SOURCE: canon x25 toner cartridge
Don't try and refill this on your own, you'll only have difficulty. Buy a reasonably priced compatible, that is "remanufactured" -not 'refilled'. It's not just toner that makes it work. The drum, cleaning blade, and doctor blade (at minimum) need to be replaced for proper operation, and there is also a toner waste hopper that needs emptying or it will overflow on second cycle.
Just my 2 cents.
Anonymous
  • 227 Answers
  • Posted on Apr 14, 2009
SOURCE: a message is poping out saying replace the waste toner container. Could you please advse where it is located on the machine?
Open the front door and try looking down to the right corner of the machine
Everett Lin
  • 990 Answers
  • Posted on Apr 15, 2009
SOURCE: Rplacing Waste Toner Container
Hello sir;The waste toner bottle right in front of the machine, when you open front door you ill see a white bottle remove and dump it out, turn power off and back on.
Cogz
Chris Coughlin
  • 1326 Answers
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Anonymous
  • 1126 Answers
  • Posted on Mar 24, 2010
SOURCE: How to install toner cartridge in a Canon 920
On your Canon PC 920, there is a recessed gray latch located on the left side of the machine towards the top front...press upwards on this latch to release the top part of copier (same as removing a misfeed or clearing a paper jam). The copier opens up.....now, located in the top unit, about center, is the drum / toner unit. It has a black plastic handle on it. Grasp this handle and pull towards you...slowly...until it is free of machine (support the rear of the unit with your other hand) Open new cartridge (unit) and install in reverse order (there should be instructions with the new cartridge) The copier has rails that the cartridge mounts on. Another note, before installing....gently shift the cartridge from side to side.....this distributes the toner evenly (again, covered in the installation instructions packed with the cartridge) There is a tab that needs to be removed to allow the toner to get where it needs to go for copying....attatched to this tab is a strip of plastic, pull all the way out. I have a PC 940...it uses the same cartridge.
Testimonial: "Thank you. Asking for a person who was given this photocopier without a Users Manual. He was pleased to have the instructions and wanted to say Thanks"
Can someone show me image of originally toner of ir2318 please
Toner cartridges for Canon IR 2318 L - compatible, original
https://www.drtusz.com > ... > Canon image RUNNER
Category, Laser Cartridges, Availability, Available in 24h. Type, Compatible, In stock, 124 szt. Class, Toner, Weight, 430 g. Color, Black, Yield, 8500 pages.
Buy Canon imageRUNNER 2318 Toner Cartridges from £31.74
https://www.cartridgesave.co.uk > Canon > IR-2318
Toner for Canon IR-2318 printer. Huge range of Canon toner cartridges. Free delivery & award winning customer service at Cartridge Save.
Toner cartridge for Canon IR 2318 / L - Compredia.eu
https://www.compredia.eu > Canon > Canon IR Series
Toner for Canon IR 2318 / L: 0384B002, CEXV14, 0384B006.
Laser Toner cartridge Canon IR 2318 [Canon IR ... - AGAWA.PL
https://www.agawa-shop.com > ... > Canon IR 2318
AGAWA.PL - Inks and Cartridges for Canon IR 2318 printers. In offer remanufactured cartridges, original products and inks for cartridge reffilling.
Canon NPG-28 Toner for iR2420/iR2318/iR2018/iR2422 ...
https://www.amazon.in > Canon-NPG-28-iR2420-iR231...
Canon NPG-28 Toner for iR2420/iR2318/iR2018/iR2422(Black) Rating: 3.6 · ‎23 reviews
Canon ir 2016j out of toner change of toner
Hello Asim.
Are you asking what toner replacement cartridge to use?
Your toner should have a sticker with this number on it.
Otherwise Google
canon ir 2016j toner renewal
The above search may also show results for how to replace.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
How to clean error 000024-01 in canon 2270
E024-0001 Error Code:
Toner gets in the developing assembly toner sensor (TS1) and may be shorting out the sensor. Blow out any toner in the sensor wiring and check to see if measure resolved the symptom. The toner level sensor has an open-circuit, replace the toner sensor.
Toner Sensor FK2-0358
However, re-attachment of the sensor also solves the symptom.
When the symptom has occurred, make the following selections in service mode [COPIER > I/O > DC-CON] and check the setting for the bit1 of [P021]. If the setting is "1", re-attach the toner sensor.
Ir2270 not sensing toner
Simple That problem is in the Developing Unit. If you check the DV you will find on one side it has gears remove the screws to expose the gears. Then look for the small round copper metal in front of a gear thats your culprit. Replacing it is the best way. Or clean it if no replacing part is available.
Error code E00024-0001 for canon ir2270
Clean DP unit (developer unit) and install toner manually Press- additional Then 2,8 ,additional press Copier ,function ,install toner ,ok if not then Replace DP censer or toner hopper censer
ERROR E0024 FOR CANNON IR2270
check the toner hopper .toner is not being fed into the developer module at set rate.clean the hopper by blowing the toner and check the toner screw motor for rotation and do check when u install toner by service mode does the toner bottle rotate.
1helpful
old marine
old marine
ZJ Limited
ZJ Limited
