Question about Stoves Kitchen Ranges
SOURCE: GE profile gas stove igniter don't stop igniting
take a look at the igniter located in the center of two burners. clean the gap with a stiff brush between the eletrode and the upper plate. the distance is preset at the factory. you may have enough buildup to close the gap enough to trigger the igniter.
Posted on Oct 23, 2008
SOURCE: Electronic igniters won't shut off.
Boy, I had a Thermador that used to drive me bats.
The best solution was to clean around the ignitor pin and make sure the orifices closest to the ignitor are not blocked... It made a big difference.
I used a small fine metal bristle brush.. did the trick.
Posted on May 30, 2009
SOURCE: igniter keeps clicking, intermittent
There should be a little switch that slips over the stem of each burner control. Very common.
Posted on Jun 02, 2009
SOURCE: Dometic 3 way RV ...the igniter strtrer just keeps
sounds like thermocouple needs replacing..easy job ? if you know what to do....
Posted on Feb 09, 2010
SOURCE: i am looking for a manual for my stoves newholme
i am looking for a manual for my stove panache 600 sidLm
Posted on Jul 08, 2010
Jan 21, 2018 | Kitchen Ranges
Aug 13, 2016 | Ovens
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
Jun 02, 2014 | Kelvinator Refrigerators
Jan 13, 2009 | Viking VGSC306-4B Gas Kitchen Range
Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
Sep 12, 2008 | Hotpoint Ovens
Sep 15, 2019 | Stoves Kitchen Ranges
Mar 11, 2019 | Stoves Kitchen Ranges
