Question about Yamaha HTR 5930 - AV receiver - 5.1 channel
My yamaha htr 5930 shuts off after about 4 or 5 seconds why?
Posted by Vickie Mosier on
john h
    Top Expert:
  • Yamaha Master
  • 23,843 Answers
Check for problem in fuel system - bad fuel - filter - carb/throttle body etc
Posted on Feb 25, 2021
5 Related Answers
Anonymous
  • 14 Answers
SOURCE: HTR-5930
To get audio from your TV through your AV receiver, please connect stereo audio cables from an available AV input on the rear of your receiver such as D-TV/LD or CBL/Sat. Then refer to your TV owner's manual for more information about audio output to an amplifier. You may have to turn off the internal TV speakers in order to get any output from the TV into the AV receiver.
Posted on Feb 17, 2008
Anonymous
SOURCE: htr 5590
Mine played for about and hour then cut off. It would cut off randomly after this hour. I initially thought it was overheating but after seeing other people had it happen after immediate turn on it must not be the case. Intermittent problems like this are difficult to troubleshoot which is why I came to this site hoping someone had found a simple answer. I am a technician and will have to do it the hard way. When I find the answer I will report my findings to this site.
Posted on Jun 18, 2008
Anonymous
  • 71 Answers
SOURCE: No video signal on Yamaha HTR 5930
On , HTR-5930, composite inputs are routed only to composite outputs. The same happens to component input. You can't see video from V AUX if your TV is hooked-up on component output. Also, check if you connected correctly GREEN, BLUE AND RED on both receiver and TV SET.
Posted on Nov 23, 2008
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: Yamaha amplifier HTR 5930 is not sending sound to
... Incorrect setup; incorrect speaker definition; speaker B selected instead of speaker A.
Posted on Jan 19, 2010
Testimonial: "Thank you. A simple solution for a non technical person."
smarthome2
Frank Fulton
  • 1114 Answers
SOURCE: I have Yamaha HTR 5930 receiver and it will power
The most common problem found on FixYa for Audio Video Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 17, 2010
How do I reset my Yamaha HTR-5930 receiver back to the manufacturers settings
Hello there
A combination of 'standby' and 'straight' buttons
You follow the procedure on page 65 of the user guide
available to download here if you have lost it.
http://download.yamaha.com/search/result/?site=usa.yamaha.com&language=en&search=HTR-5930
Sep 24, 2014 | Yamaha HTR 5930 - AV receiver - 5.1...
Surround problem with Yamaha HTR-5930 5.1 Channels Receiver
The signal that comes from most tv's via the optical output is a stereo signal only. That is what your receiver is reading. You would have to manually set your receiver to decode the signal into surround,.
Apr 18, 2013 | Yamaha HTR-5930 Receiver
I am trying to figure out how to connect my ipod to my Yamaha htr-5930. Can I do that through the headphone jack, or through the aux jack? Is there anyway I can do this? Thanks! [email protected] is where...
Use a 3.5 mm to 2Male RCA cable. Plug this into an AUX or CD input in the back. Adjust the volume on the iPod as well as the master volume to balance out the sound. The headphone on the receiver is output only.
Apr 12, 2011 | Yamaha HTR-5930 Receiver
I have a Yamaha HTR-5930 Home Theater Sys. Somehow, I've managed to lose my right channel when watching T.V. (dish network), but when my son plays with the XBox, he gets full surround stereo. Any ideas?
The XBox is probably hooked up separately to the amplifier, try cycling the inputs on the amplifier. If that doesn't work replace the cbale between your amplifier and tv.
Nov 19, 2010 | Yamaha HTR-5930 Receiver
I hit the power button and then it comes on and two seconds later, it turns right off.
you most likely have audio output shorted, when that happens the unit goes into proteccfion to prevent furter damage, you must have it repaired
Dec 19, 2009 | Yamaha HTR-5930 Receiver
YAMAHA HTR 5930 CENTER CHANNEL NOT WORKING. PLEASE ADVISE
makesure the ampis set on dolby prologic 3 channel
Jan 02, 2009 | Yamaha HTR-5930 Receiver
Jun 30, 2008 | Yamaha HTR-5930 Receiver
Yamaha htr 5930
I think you have to adjust balance.
Page 22 of user's manual explains how to do it:
May 24, 2008 | Yamaha HTR-5930 Receiver
HTR-5930
Feb 17, 2008 | Yamaha HTR-5930 Receiver
Yamaha HTR 5930 - AV receiver - 5.1 channel Logo
Top Yamaha Audio Players & Recorders Experts
Will
Level 1 Expert
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
