Question about The Optics
Spray it with a dry silicone spray like Jigaloo. Put a very small amount on the underside to test as it can sometimes damage plastic. It is a great product though.
Posted on Apr 09, 2021
SOURCE: Sighting in my scope
That should be covered in your manual.
If not, give Nikon a call.
Or, repost your question on a Bulletin Borad such as at SWFA, where another user may have the identical scope.
Posted on Nov 26, 2008
SOURCE: Problem sighting bushnell lazer boresighter
If you are attempting to use a red laser in daylight, you have to wear special glasses to see it well. You may have to complete this project with less light, such as after dark, or indoors. Only green lasers will show up in daylight. If this is not helpful, then I suggest that you change the batteries to brand new ones that you are sure of. There is probably no adjustment possible. Best wishes for your safe shooting!
Posted on Jan 05, 2009
SOURCE: older hunter original, needs lubrication.
Howdy,
This is the owner's manual to your fan
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41121.pdf
As for oil, you can use one of two oils. Depending on how old your fan is, I suggest changing the oil by removing the fan, turning the motor completely over and letting it drain into the "dish" on the part that spins, clean the oil out of there, then re-hang the fan and oil with 1 oz of either Hunter Fan Oil (which is available from hunter, or on ebay, just search for Hunter Original Fan) or Zoom Spout Oiler, both are the same oil.
Thanks
Posted on Sep 23, 2010
May 20, 2018 | The Health & Beauty
Dec 15, 2017 | 2006 Honda Reflex
May 30, 2014 | Mueller Quick Shot 1x33 mm Black Reflex...
Feb 10, 2013 | Browning Buckmark Holographic Sight...
Apr 30, 2010 | Yahoo Mail
Oct 13, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
May 04, 2009 | Leupold ® Rifleman® 3-9x50 mm Scope
Feb 01, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Aug 02, 2008 | 2003 Ford Explorer
