Green picture distortion on HDMI TV - Televison & Video
Posted by Katherine Taylor on
    Top Expert:
  • Televison & ... Master
  • 76,573 Answers
Distorted white balance adjustment. Do it. You have to enter its service mode to perform it. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
https://elektrotricks.blogspot.com/
faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Feb 25, 2021
5 Related Answers
paul proctor
  • 4102 Answers
SOURCE: hdmi not working on brand new haier hd tv
are you using hdmi leads and how are you recieving hd are you recieving it through a box
Posted on Jan 16, 2008
pazybien
SOURCE: Black/Green Distortion - Picture Quality - Wharfedale
This is no solution but a point in a probable direction.
A tech guy told me ALL the LCDs they have seen in their repair shop have "swollen" capacitors, this is due to voltage instability. Lowering the internal voltage regulator and replacing the swollen capacitors (which eliminate noise) apparently restores the LCD to new working quality. Without actually "seeing" my problem the tech said that should repair it. I have not tried this yet but eventually will begin that way.
Posted on Jun 08, 2008
Anonymous
  • 4 Answers
SOURCE: distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Posted on Aug 03, 2008
welcomejee
Shahid Electronics
  • 10594 Answers
SOURCE: picture suddenly distorted, green and violet lines
It is convergence out ICs failure problem and you need to replace two ICs in convergence board/ section in TV.
If you are not familiar with TV repair then call qualified TV tech to fix it.
Posted on Apr 15, 2009
Anonymous
SOURCE: Distorted color on hdmi output
If you haven't already stumbled across the fix: I just had the exact same problem after about eights months of casual use. Unplugging the DVD player for about 15 minutes and then plugging it back in "solved" the problem. Until next time it happens, anyway.
Posted on Jun 01, 2009
My Sony Bravia picture turns green.
check cable, if its using an HDMI, replace it: if component RGB cable, reseat or replace.
Oct 03, 2015 | Sony Bravia KDL-46Z4100 46 in. LCD HDTV
I'm having a problem with the color green being distorted on my TV. Is this a color tube issue, bulb issue, lamp issue?
This is a picture tube type TV. No lamp.
You don't describe the distortion.
A colour green picture that is twisted and shifted away from the other colours is a convergence problem. see Projection TV Convergence on this site.
If the green is smeared, out of focus, larger than the other colours like a halo around objects, things like that, it is the green picture tube. Sony has discontinued most of the picture tubes so you may not be able to get this fixed.
Mar 31, 2010 | Sony KP-46WT520 46" Rear Projection...
Green squiggly line distorting picture on TV
Ur Convergence is dead.Parts and labors,about $300 dollars.
Jan 07, 2010 | Televison & Video
Sony KDS R50XBR1 TV, LIME GREEN PIC
if all sources and hdmi cable are good--you need the hdmi input board--dont know sonys letter designation
Jul 22, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Apr 17, 2009 | Philips DVP5990 DVD Player
Distorted picture on RCA LCD TV
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Mar 11, 2008 | Televison & Video
Hdmi not working on brand new haier hd tv
Jan 16, 2008 | Televison & Video
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
