Question about Health & Beauty
True Metrix glucose tester - I get E0 when I put the blood on the test strip of my true Metrix every time
Posted by Larry Dodd on
victor mwasaru
  • 4 Answers
The test strip may be damaged or the code key is incorrect. Remove and reinsert the test strip
Posted on Mar 02, 2021
2 Related Answers
john h
  • 23818 Answers
SOURCE: my blood test for glucose is 1.5
for inquires -or questions on your glucose ,blood work or lab work do it with your doctor not a web site that has no info or medical history about your or your health
Posted on Nov 25, 2016
drstan69
Stan Naramore
  • 531 Answers
SOURCE: How do I clear all memory on a True metrix glucose meter?
There is no internally programmed way to clear the memory.
The memory will hold 500 glucose readings.
When 500 readings are obtained it will erase 1 reading for every new reading.
Previously stored readings cannot be erased.
If is difficult to conceive why anyone would want to erase glucose level reading.
With other older glucometers some people have tried leaving the battery out for 24 hours and passing a strong magnet over the glucometer.
Because many physicians depend on the readings of their patientm's glucometers and they do not want the patient's manipulating the readings many glucometers do not allow
erasure.
Posted on Aug 20, 2018
REASONS FOR FLASHING BLOOD DROP SYMPBOL ON CHOLESTEROL METER WHILST STRIP WAS COVERED CORRECTLY WITH BLOOD
I use an Abbott Precision Xtra glucose / ketone tester, that sound similar to yours. On mine, you do not place a drop of blood ON the strip, you place the end of the strip in the drop of blood. There is a very narrow channel that then sucks up the blood by capillary action, and in the case of my tester, it beeps to acknowledge when it has enough.
On the colored side of my strips you can see the blood rise in the opening. After the beep the symbols change to a countdown while the meter does its work
I hope this will gice you at least one thing to try and observe the results of.
It is possible you had a bad strip. It does not happen often, but it does occur from time to time.
Good luck
John
Sep 17, 2016 | Health & Beauty
WHY IS NO CODE NUMBER APPEARING WHEN TEST STRIPS ARE INSTALLED?
THE CODE CHIPS HAVE CHANGED, THEY NO LONGER NEED A NEW CODE CHIP WITH EACH SET OF TEST STRIPS. WILL WORK SO LONG AS YOU HAVE ANY CODE CHIP IN YOUR TESTER. HOPE THIS HELPS
Feb 04, 2016 | Accu Check Aviva Plus Blood Glucose...
The meter says E 5 on it what does this mean ?
Cant remember exactly but i think that is probable blood incorrectly put onto test strip, probably before meter is ready. You have to wait for the little drop of blood to appear on the display.
Mar 15, 2015 | Accu Check Aviva Plus Blood Glucose...
Optium xceed user manual
Blood put on to test strip too soon, you need to wait a short while after fitting strip before putting blood on for testing. Not sure of exact time but the machines display should change. Hope this helps
Jun 23, 2014 | Health & Beauty
My easy touch meter is reading way to high how do I fix it?
How do you know it is reading watch too high is my first question..MAKE SURE IT IS NOT YOUR GLUCOSE THAT IS READING HIGH..the tester should have a small bottle of testing accuracy with it..there are number scales on the side of the strip container and on the test bottle use a strip and test it..if it reads on or between the numbers the strips and tester is ok..if it does not, try another from another strip from different container..if it still reads wrong..your tester is faulty..good luck..
Apr 23, 2014 | Easy Touch No Coding Glucose Monitoring...
WHEN I TRY TO CHECK MY BLOOD SUGAR, IT EITHER SAYS ERROR 2 OR ERROR 5
Error
1 too hot or cold
2 sample not detected or using wrong strip
3 used strip, stip out too long or blood on top of strip
4 meter error call for help
5 very high blood glucose (600+)
6 strip removed during test
8 memory error, result not recorded
9 communication error.. call for help
hope this helps, please note that online manual is available if you search for it online, and this is why it is immportant to keep all instructions in a safe place.
Jan 13, 2014 | Walgreens Trueresult Blood Glucose Meter,...
User guide for optium EZ blood glucose tester
set of instructions should be in box, or read machine instructions
Oct 24, 2013 | Medline Abbott Diabetes Care Glucose...
How do i also clear off all of these dangerously high blood sugar readings from the glucocard vital blood glucose meter?
Directions should say.try taking the battery out eat more veggies and exercise I've had it 41 years. God bless
Feb 25, 2013 | Arkray GlucoCard Vital Sensor Blood...
I want to know the normal average of my blood glucose in ascencia contour.
The first thing to do is to get the ascencia contour strips then plug it to the meter. It has a sip-in action that accepts a tiny blood sample into the strip. The result of your blood glucose will appear at the screen. You must look for patterns in your blood sugar readings and vary the times that you test. Consider testing 2 hours before and 2 hours after the first bite of your meal. You must perform this each meal to learn how your body is reacting to your food, exercise, medications and etc. You can also test your blood glucose at bedtime or even at the next morning to see what occurs overnight when you are not eating for several hours. this is fasting blood sugar. By doing these, you can compare the results of your blood glucose level and you can also know the normal level of your blood glucose.
Jun 09, 2011 | Health & Beauty
Health & Beauty Logo
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
ray gallant
Are you a Health and Beauty Expert? Answer questions, earn points and help others
