Question about Health & Beauty
I have a kymco agility mobility scooter,new batteries new brushes. I am only getting 4/5 miles on a full charge
Posted by Jack muscroft on
Rob Hill
  • Health & Beauty Master
  • 1,426 Answers
Hi, have you tried another charger ? its important as you have replaced the batteries...
Regards
Rob
Posted on Mar 03, 2021
5 Related Answers
Anonymous
SOURCE: battery power on mobility scooter
The Hand Control has probably bent in from use. ( Where she Pushes the throttle Control )
Grab a hold of it and bend it out towards you slightly
The part about the indicator going down when she moves and back up when she stops is normal
Posted on May 07, 2009
oregoon
  • 175 Answers
SOURCE: The battery takes a charge, but will not power scooter
This scooter require two batteries, not one. It is usually a good idea to replace both batteries at the same time, even though one is obviously bad, and the other "seems" okay. These 12 volt DC batteries (VDC) work in tandem to produce the 24 volts that the scooter operates on. In a perfect world, they would both live a long and happy life, but reality is that some die young, others old. Since they are joined together, the one that's going out saps the life out of the other one, so take a bullet and replace both batteries. Make sure you completely charge the scooter when you get the new ones in. Verify that your charger is working properly. To properly charge the 24 VDC system, the chargers have to have an output of about 26-28VDC. The output must be higher than the rated voltage of the two batteries put together to charge. While you have the shell off the scooter, you can see if the charger is working by measuring across the terminal on each battery with the charger off. Note the meter reading. It should be 12-13 VDC. Put it on the charger and retake the reading, and each battery should show an increase in the voltage due to the boost from the charger. After three hours, each battery should show about a 13.5 VDC reading which should hold above 12 for a good 8-10 miles. Always charge your batteries overnight, and if not in use, disconnect them completely with a full charge on the batteries.
Posted on Jul 12, 2009
william bennett
  • 945 Answers
SOURCE: shoprider cadiz scooter, batteries show full
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Posted on Nov 06, 2009
Azrael SRL
  • 11800 Answers
SOURCE: Have Shoprider Sovereign 4 Scooter.
The batteries are weak - either they are worn out or they are defective. They will have to be replaced.
Posted on Oct 23, 2010
andy
  • 33 Answers
SOURCE: 2007 kymco agility 125cc scooter
could be one of a few things. Most likely fuel related. 1) carb blocked main jet (whip it out n clean it) 2) air filter clogged up or split (remove spark plug and if it is black there is too much fuel and either the airfilter is blocked up or the choke is stuck on, if it is very white there is too much air getting infrom either a split air filter or leaking inlet pipe) 3) change spark plug.
Posted on Jul 02, 2011
I have a kymco agility mobility scooter and there is a very noticable clicking noise when its moving. Help?
Hi tighten the axle nuts ...if this does not help loosen axle nuts jack it up tighten nuts & when on the ground tighten them again, cheers
Aug 25, 2016 | Kymco Maxi XL Mobility Scooter
Why won't my Kymco start? Has power to everything and the relay swifch clicks, that's all it will do
KYMCO Agility 50 Scooter Online Service Manual ...
https://www.cyclepedia.com/...manuals/kymco...scooter...repair-manuals/...
The CYCLEPEDIA PRESS LLC KYMCO Agility 50 Scooter online service manualfeatures detailed, full-color photographs and wiring diagrams, complete ...
Aug 11, 2015 | 2013 Kymco Agility 50
How to replace the carbon brushes please.
After procuring the correct replacement brushes simply unscrew the plastic cap securing the brush to the motor, remove the old brush, insert the new one and secure the cap to the motor. You will have to run the motor a while for the new brushes to seat properly so don't expect the motor to produce full power instantly.
Jul 15, 2015 | Kymco Maxi XL Mobility Scooter
My kymco midi goes ok for about 1 mile then slows and then stops the battery ok can it be the motor
Hi there i would get it fully serviced before it breaks down completely a full service would cost you 50 pounds
Pete
Oct 09, 2014 | Kymco Midi XL 8mph Mobility Scooter with...
How many miles can I get from a fully charged Freerider Ascot 4 mobility scooter? My scooter seems to run out of charge after a few miles.
11 miles on full charged new batteries, this is approximately as condition change max distance, like you weight, if you are going uphill, how even the ground is etc. if you need more you could get a spare battery pack for it, and swap them over when needed. but remember to keep them charged even when not in use once a week is the best way to keep them in good shape.
Sep 09, 2013 | Health & Beauty
Charging
i would say it all depends on how many AH your battery is and what amp your charger is they differ between 8 to 14 hours that is for new batteries as a battery gets older the less time it takes to charge so if your batteries are getting fully charged in 2 hours its time to start thinking of changing them
good luck and hope this helps
clive
Jan 17, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Health & Beauty Logo
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
ray gallant
Are you a Health and Beauty Expert? Answer questions, earn points and help others
