Question about The Computers & Internet
Whenever i am trying to copy my files or trying to create something new in my external drive it shows me this error code how could i get rid of this can anyone help me out??((Error 0x800701E3: The request failed due to a fatal device hardware error))
Spam spam spam spam qergqeporighqpo3hrgpoq3hgpohq3porghpoqehrpoghqpweorhgopqhwerephogq3rwohopgh3rwoghw3r
Posted on Feb 25, 2021
SOURCE: I/O Device Error on External Hard Drive
try doing a disk check on it
1 hold down the windows key and press r
2 type in cmd
3 in the shell window type in chkdsk /F /X e:
Replace the E: with your harddrive letter
Posted on May 04, 2008
SOURCE: psp: I/O device error.
Its 100% because of the Bad cable.. Change the USB cable it will work fine
Posted on Jul 24, 2008
SOURCE: Windows has encountered a problem communicating
I had similar problem with a Dell Optiplex 760 desktop . I went to BIOS disable external SATA and all additional ports which is not used like parallel and serial ports and it worked. I think its with SATA settings only .
Posted on May 25, 2009
SOURCE: an mtp device cannot start due error code 10 whats that
I solved the code 10 problem on my vista 64 by using Revo uninstaller on the next to highest level to remove Acronis 10.4942 After this all media readers appeared and worked. A later version of Acronis Emergency boot disk still works to backup/ restore my system
Posted on Jun 22, 2009
SOURCE: Fatal error installing HP 3055 all in one
OK, here is my debugged/tested solution.
I know your error refers to a different installer MSI file (CIOUM32.msi) but the installation component in your log file (ipm12.A4B24390_80AD_4BAF_B8FD_C670FE0DB586) is identical to the one that was giving me trouble as well (i.e. points to the same service/file). So it is definitely worth a shot to try this solution out as it will only take a few minutes.
My Scenario:
OS: MS Windows XP SP3 [Version 5.1.2600]
Printer: HP LaserJet 3390 (AiO) (Firmware datecode: 20070331)
Printer Connection: Connected via Ethernet with a static IP address
HP Driver Version: v4.0 (hp_LJ3050-3052-3055-3390-3392_Full_Solution_AMWE.exe)
Ran into same error that everyone else is experiencing. (see below)
Now Launching=X:\hpzmsi01.exe -m dot4msi -l XXX -f X:\DIVins??.DAT
Error message received: The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2753.
X:\HPZBDI32.msi failed with return code 1603
MSIInstall() failed with 1603
Exit code=1603
After debugging HP's installation scripts for 2 days, here is the cause & solution I identified to this specific install error. Once I got passed this error, everything installed without error and all functionality was working properly (including scanning!).
BACKGROUND:
Microsoft Installer (MSI) error 1603 is simply a generic "A fatal error occurred during installation" -- see http://msdn.microsoft.com/en-us/library/aa368542(VS.85).aspx. This is basically MSI telling you that something very bad has happened during the installation. In order to get more details, you can turn on MSI debug logging by following this MS Knowledge Base article (http://support.microsoft.com/kb/223300).
The MSI error code 2753 is the code for "The File '<file name>' is not marked for installation.". This error can be triggered by many scenarios, but usually, it has to do with the actual installation script not properly checking for the existence/non-existence of an installation file and then not marking it for either installation/removal. I know this sounds confusing, and it is. If your curious about all the possible causes, just Google for "msi 2753 not marked for installation" and you'll see lots of results which you can peruse for your own enjoyment.
In order to identify what was causing these 2 errors, I enabled debugging for MSI via the aforementioned MS KB article
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
If all goes well, the install should now run without any issues.
Hope this helps since many people (including myself) have spent a lot of time (and HP Support chats) trying to find a workaround for this issue.
If you find this solution helped you out, please feel free to make a small donation to my PayPal ;)
Posted on Oct 30, 2009
Oct 25, 2013 | Computers & Internet
Jun 04, 2011 | Microsoft Windows XP Professional x64...
Oct 28, 2010 | IBM x3400 Server
Oct 19, 2010 | Computers & Internet
Sep 23, 2009 | HP ScanJet 2200C Flatbed Scanner
Sep 09, 2009 | Office Equipment & Supplies
Apr 17, 2009 | GPS
Mar 16, 2009 | Computers & Internet
Nov 25, 2007 | Toshiba Satellite Pro 4600 Notebook
Feb 24, 2021 | The Computers & Internet
18 people viewed this question
on what, no PC told no OS told we can NOT guess all that and what is connected to any PC on earth.
the HDD is bad, is #1 reason ever think to test it next,? no hDD told by you.
100% free to you.(home use) learn to use it every month to avoid data loss, be wise.
https://www.passmark.com/products/diskch...
run it see if the HDD is bad, any HDD or SSD.
as they say first things first.
no external drive told by you and if it is 3.5" drive that must have power pack to run the think, none told by you.
the error means bad sectors on HDD.
this answer is for free help never spam.
above. passmark.
The error message “The request failed due to a fatal device hardware error” appears when the user tries to copy or send files from the laptop to an external hard drive. And here are the main reasons it happens: Cable problems. It may be damaged or poorly connected.
I will walk you through with several top troubleshooting methods to fix error 0x800701E3.
https://www.partitionwizard.com/partitio...
