Question about Vintage Watches
I have removed back cover of watch. I removed the existing batteries years ago to prevent corrosion. I do not have access to a watch shop. Only need battery size to order correct battery size from Amazon. Thank you
Tip & How-To about Watches
Changing Watch Batteries
Lots of posters ask "what is the battery in my (name of watch)" with a view to changing it yourself. This is a bad idea for many reasons. You don't have the tools or knowledge to remove a rotary screw on back, or the gasket sealant for a waterproof watch. Some fashion watches have 4 traditional screw and need professional grade jeweler screwdrivers. Also, there are about 20 batteries commonly used in watches, in various sizes and internal technology, Lithium Ion, Silver Oxide and Manganese Alkaline. If you buy them, you generally have to buy 10!
Don't sweat the details. Just take the watch to your local jeweler. They have all the batteries at hand and the tools to remove the back. It is done whilst you wait for $8 to $15!
Posted by MODERATOR... on Dec 31, 2018
Posted on Feb 23, 2021
SOURCE: Invicta 2875 wrist watch band too large
http://www.geocities.com/watch_crazy/bands/bands.htm
Posted on Jun 30, 2008
SOURCE: my watch needs a new battery.
There is a tool that you need that adjusts to the three holes or openings in the back of your watch and it just screws off. If you don't have access to the tool, simply take two push pins and CAREFULLY insert them into the openings and unscrew the back cover. Remember that it unscrews counter-clockwise.This will give you access to the battery simply take it out and go to the store to buy a replacement repeat the process to install the cover back on.
Posted on Nov 28, 2008
SOURCE: how do you open Vintage Men's Omega Deville Wrist Watch?
That means you have a monoblock case and this can be opened using a special pump and forcing the air into the case through the tube (where the stem is inserted into the movement).
When forced in, the air pressure builds up in the case and lifts up the watch glass.
It is quite tricky operation and need skilled watchmakers hands and tools.
When I first used this metod, air pressure was so strong, that it shot out the glass from the case together with the movement and all the watch bits flew over the place, ending with damaged fingers, scratched dial and broken balance staff, so, I had to buy them and replace.
My advice is to go to your nearest watch repair shop and ask for help, as you wont be able to open your watch without proper tools or you will damage or brake watch glass.
Don't forget to rate, please.
Posted on Jan 19, 2009
SOURCE: athletic wrist watch stuck in 24 hour mode
Maddening, isn't it? Fortunately the solution is here:
http://www.ehow.com/how_5593310_set-athletic-works-watch.html
1 There should be four buttons: mode, reset, start and light. Find the mode button and press it three times until it is in the set time mode.
2 Find the reset button, which usually is located on the bottom right side of the watch face, and hold it until the time starts blinking.
3 Press the start button to change minutes.
4 Press the reset button again to switch to hours.You will know it worked when the hour starts blinking instead of the minutes.
5 Press the start button to change the hour. The watch can handle two modes: standard and military. As you press start, the hour will change from AM to PM, noted by an "A" or a "P" in the top right. When you get through 24 hours, the watch will change to military time and an "H" will be displayed instead of "A" or "P." Keep pressing start to go through another 24-hour cycle and it will revert back to standard time.
Posted on Jan 05, 2010
SOURCE: My wrist watch is continuously losing time. It is
go to the Timex web site "timex.com".
Scroll down to the bottom of the page and select "manuals/downloads."
Select "Product manuals downloads"
Enter you model number in the search box.
Choose your download from the list.
