If still has power check gas pressure if ok check burner tubes for blockage if unit tripps breaker check ignitor if lights but goes out check flame sensor
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow whi ch I don't prefer... rest is up to u.. U can also get free manuals
Any mechanic with a scanner that is air bag compatable. If your system doesn't have an issue, the light will go off...you have a problem, so get it scanned to see what is up.
This sounds like a low voltage problem .. you can check all your connections AFTER you shut down the power and tighen them all the way back to the breaker.. When electrical demand is high it is common for voltage will dropp. Hope this helps
If you want to know if your battery works or not. Heres a simple way.
Use your laptop without using the AC charger. If the Laptop stays on for atleast 30mins and above that means your battery is ok. specially if the laptop stays on for 4-5 hours, your battery is working 100%.
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
First thing to check is the flow switch. You can bypass it temporarily, and see if it lights. DO NOT OPERATE IT WITHOUTH FLOW SWITCH. If it isn't the flow switch, then it could be the thermostat or a bad connection on this low voltage millivolt circuit.
use a small allen wrench.you must also use a multi meter. if you are not familar with using continuity mode,i strongly suggest calling a qualified repair person.if not adj properly,htr can come on with pump off which could result in "china syndrome"
