For a CRT TV it could be that the parts inside of your TV's speakers and the parts that allow sound and control the sound and the sound input inside of your TV need to be replaced if you are talking about a CRT TV here.
Posted on Feb 21, 2021
SOURCE: Akai TV volume control stuck on 100%
try leaving the set unplugged for several hours, this will reset it to factory settings. If this does not work you need service.
Posted on Jan 10, 2009
SOURCE: Mute is on when I turn my vizio on. How do I
The OSD consists of several menu options: Picture Adjust, Audio Adjust, TV Tuner Setup, Parental Controls,PIP Set Up, or Special Features. When in the TV menu, select the Audio Adjust and make sure the mute is off. It may be worth checking the manual which is avialble from: http://www.vizio.com/downloads.aspx
Posted on Aug 20, 2009
SOURCE: I stopped having sound coming from the speakers.
Make sure all your connections are tight and you have power to your speakers...Then go Start>Control Panel>Sound and Hardware>Sound, after you are in here make sure that your speakers are selected as default device.
Hope this helps, pls rate
Posted on Mar 19, 2010
SOURCE: scratchy sound coming out of my PC speakers and
its ram problem clean ur ram slots and ram pins,check ur harDdisk power cable (if SATA FIX IT WITH SOME QUICK FIX)
Posted on Oct 06, 2010
SOURCE: My Panasonic plasma screen TV is stuck on mute? I
Did you press the mute button again, some TVs use this method.
Posted on Jul 07, 2011
Mar 03, 2015 | Televison & Video
Sep 08, 2014 | Televison & Video
Apr 03, 2012 | Mitsubishi Televison & Video
Jan 09, 2011 | Sharp Televison & Video
Press MUTING to mute the sound through all
speakers and headphones connected.
"MUTING" appears on the display and the
volume turns off (the volume level indicator goes
off).
To restore the sound, press MUTING again so that "OFF" appears
on the display.
• Turning MASTER VOLUME on the front panel or pressing
VOLUME +/- on the remote control also restores the sound.
Dec 22, 2010 | JVC RX-778V
Oct 14, 2010 | Aiwa F2000 20" TV
Feb 27, 2010 | Televison & Video
Jan 11, 2010 | InFocus X1 Multimedia Projector
Jan 04, 2008 | Behringer FCA202 - FireWire Audio...
It is a CRT style TV then.
