My laptop screen is jumping or flickering pls help
Posted by Audience Ngobeni on
  • 3 more comments
  • Larry Ng
    Larry Ng Feb 21, 2021
    wow like the first photo posted here in
    months, (by volume rare) way to go Audience.
    That is one sick Lappy.
    i this a 2008 PC? GPU solderball ddeathh PCs.
    does it do that in BIOS screens.
    NO PC told ,no OS told I can only ASSS-U-ME
    that screen is the OS?
    test 1, run the PC with no huge battery first. just on AC power pack alone.
    fails still
    unplug PC for 1hour , no huge battery connected no AC pack
    put back only the power pack AC
    then power on and hammer the secret BIOS key on this secret PC and see if BIOS screens are Ok? if fails here too
    we then try using the secret PCs External video port to a test monitor or TV.
    VGA,HDMI,DVI,DP are the 4 classes of external display ports used in last 20 years.
    all not known due to NO PC told
    if HDMI port connect it to a TV.
    if not get monitor that matches said port or and adapter and test the PC using an external
    monitor (or TV + HDMI)
  • Larry Ng
    NO PO told of 100,000 models
    we can NOT guess PCs, ever.
    hp,dell,acer,asus,lenovo, and more. lots more
    and many have model stated on bottom of PC
    or in battery well of battery simply drops out. or in BIOS screen #1
    THE GPU is not happy or the LCD is bad.
    testing proves this, but no PC told making exact answers impossible. (risking wild guessing by most)
  • Anonymous Feb 21, 2021
    tech answer
    power bus in PC overloaded, a pure power cause.
    the GPU is sick ,bad or driver dead wrong.
    GPU fails in BIOS tool, that is bad GPU.
    but can be bad LCD. for sure Laptop dropped or hit. by anything.
    the only easy proof is :
    1: remove huge battery . run AC only.
    2: connect PC to TV or monitor if works that way LCD is bad. (most times)
    3: if only fails in windows, the drivers are wrong. for windows, or not the right ones matching say w10, get them from your unstated OEM PC maker, just them.
    one other problem is bad service
    seen PC with loose LCD cables inside ,due to bad service done, and not put back as they found them secure, now are falling half off the connectors deep inside.
    why not just get the PC serviced like 99% do?
    many of these PCs have 35 screws to even get at the parts that fail inside or even inspect it. NOT mine it is a DELL.
  • Audience Ngobeni
    Audience Ngobeni Feb 21, 2021
    I tested on a pc screen with VGA cable it works fine... so I think it's bad LCD,
  • Audience Ngobeni
    Tested it's working well on monitor
Aron
  • 1,700 Answers
In order to test and see if the issue is coming from malfunctioning wires lower and raise your laptops computer screen repeatedly to check and see if the flickering is related to movements then. Either it is a loose or a damaged screen cable or an inverter or the back light are all the possible culprits behind your particular laptop screen flickering woes.It could be the screen is starting to go bad and needs to be replaced.
Posted on Feb 21, 2021
Nahayo Jean bosco
Disconnect screen cable and connect then turn on again
2 Related Answers
Anonymous
  • 76 Answers
SOURCE: i have a fujitsu siemens laptop and the screen
The first thing you need to do is check the screen connection to the motherboard.
Without knowing the model of the laptop I can’t really advise you on how to do this, however it’s normally under the power on button strip.
If the connector is tight and in place it will most likely be the screen inverter which is under the fascia of the screen.
Whiteout knowing the model it’s difficult to offer advice.
Posted on Feb 17, 2010
macfix
michael ramos
  • 86 Answers
SOURCE: laptop screen flickers
try to plug the laptop to a external monitor. I the display doesn't flicks your Motherboard or the graphics card fine and you need to replace your screen LCD
Posted on Aug 21, 2012
Laptop screen flickers
Aug 20, 2012 | Lenovo G530, G550, G560...
Dell laptop matter on the screen flickers
If it happens after sometime when you turn on your laptop and working on any application, it is the problem of your laptop's screen, you need to repair it.
Dec 17, 2011 | Computers & Internet
The laptop screen flickers all the time and it distorts the screen. If i plug into a desktop monitor that works fine. What is the problem? and how do i fix it?
hi chizuk, if the screen flickers all the time, pls call our support line at 1-877-4-536686. This issue needs to be addressed and it is possible for a depot repair due to screen problem.
Hope this helps...
May 08, 2010 | Lenovo IdeaPad Y510 Notebook
I have a fujitsu siemens laptop and the screen keeps flickering and jumping, can u help please
Feb 15, 2010 | Computers & Internet
My Hp pavillion dv4 notebook pc's screen is flickering quite badly. It happens every few seconds and everything seems to jump up and down once and go back to normal. Tapping or hitting screen or any part...
Flickering is a back light issue, jumping around would be caused by the screens reaction to a bad inverter and so would the backlight as well. So flickering backlight and jumping would be a inverter issue causing both problems so I would replace them both.
Thanks if you like my adivice please rate it with the thumbs and leave feedback!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Dec 19, 2009 | HP Pavilion dv4000 Notebook
Flickering screen
My screen flicker on xp but on win7 please help me?
Regards, Chas
Jan 06, 2009 | Acer X193W LCD Monitor
Flicker and very slow
turn off your PSP ,then switch on again.. when the screen are in black condition "press R button" and change the CPU speed
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
