Question about Refrigerators
I have a criterion model number CTMR99M1B It just started freezing everything in the fridge, any thoughts
Posted by Danny Hall on
Real Cool
    Top Expert:
  • Refrigerators Master
  • 33,520 Answers
Check the thermostat settings.
Posted on Feb 19, 2021
Everything on top shelf of fridge freezes even on lowest temperature
you should send model number,if you have a damper control in your model most likely this is the problem,all that happens is cold air blows over from the freezer from the evaporator fan and blows through the top section of the fridge side,if the damper door isn't closing all the way it will cause freezing in the fridge section.
Nov 25, 2013 | Hotpoint Refrigerators
Kenmore 50522 refrigerator freezing everything
What is the model number listed in the refrigerator section?
Oct 15, 2012 | Kenmore 50522 / 50524 Side by Side...
Mini Fridge freezing everything
Yes, thermostat and when they go bad they eiter sop , keepgetting colder or out of calibration, I will see if I can find one, Really any small two wired refrigerator thermostat wil be fine, Sea Breeze
Mar 18, 2010 | GE SMR03BASWW Compact Refrigerator With...
EVERYTHING IN FRIDGE IS FREEZING,EVEN THOUGH CONTROLS ARE TURNED DOWN,ANY THOUGHTS ON THIS?
You are having a control issue either with the thermostat or an auto damper or both. I will need the model number of your refrigerator to point you in the correct direction, Thanks, Sea Breeze
Feb 22, 2010 | Amana Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Food in fridge is freezing.
I need your model number, you may have a problem with your thermistat. Sears uses a different model number system than everyone. The model number will look like this 231.0564879 for example. Or yours may have electronic vents. Let me know, Thanks, Sea Breeze
You may need to contact me because Fixya has a problem letting me know if you respond.
[email protected]
Jul 20, 2009 | Kenmore 53082 / 53084 Side by Side...
Everything in Fridge side is freezing
your thermostat is probably defective. is an electronic or mechanical thermostat? there is a website called repairclinic.com. where you can enter your model number and get tech. help along with part #'s., its a very good website
May 08, 2009 | Refrigerators
Danby compact 482 fridge is freezing everything. thermostat switch seems to check out.
Hello tbrown7777
Welcome.
You said, Your Danby compact 482 fridge is freezing everything. thermostat switch seems to check out.
Just 482 is incomplete!!!!!!!!!
Can you send me the complete model number off the sticker in the fridge or on the rear of the fridge?
and the year of it! waiting your response!
Huuum
Oct 20, 2008 | Danby Refrigerators
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
john h
