Question about NEC Office Equipment & Supplies
NEC NP310 projector, can I replace the fan?
We are having 4 red blinking lights that in the manual indicate that there is a fan issue. Do we just need to replace the lamp? Thanks.
Posted by Jessica McDonald on
Real Cool
    Top Expert:
  • NEC Master
  • 33,520 Answers
Your statement indicates'there is a fan issue'.
It may just require cleaning but may need replacing. Nothing to do with the lamp, unless it has overheated and also needs replacing.
Posted on Feb 19, 2021
Testimonial: "Do you know how I find a replacement fan? The manual has no indication on how to replace it."
  • Jessica McDonald
    Jessica McDonald Feb 19, 2021
    Sorry, new to the site.
  • Real Cool
    Real Cool Feb 19, 2021
    Have a look here; https://www.youtube.com/watch?v=NqmlNrmQ...
How do I get my PS4 to play via NEC NP310 Projector (it has no HDMI input)?
Remember, that a DVI and a DVI-D are different cords. DVI-D carries sound just like the HDMI. One possible solution is to try a HDMI-RCA adapter. You will see a reduction in resolution though.
Jul 29, 2015 | Sony PlayStation 4
NEC M420x blinking and no light, can help me /
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
Dec 10, 2013 | LG RD-JT52 Replacement Lamp
The status light is on our NEC MT850 and the bulb looks fine. What other problems could it be?
1,Check the fans ,whether each fan is running,when you turn on the projector
turn on the projector ,at the same time ,if you can hear a continuous beep beep sound (the ballast igniting the lamp)
means the lamp may be fault,and other parts is working well
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 19, 2012 | NEC MT850, MT1050, MT1055, MT1056...
NP310 NEC Projector shuts down after about 15 min.
Check for good air flow: that filters are clean and the fans are running and not blocked. Check the bulb hours - it may be nearing the end of its life expectancy. If heat is the problem, the inside temperature sensor will shut down the machine or it may be faulty. Inside electronics would be the next suspect.
Feb 07, 2011 | NEC NP61 DLP Projector
Nec lt20 how to repair "cooling fan not operating"
you'll need to replace the fan. however, nec does not sell parts. you'll need to send it in to them. unless you remove the fan and, using the part number on the fan, search the internet for a replacement. try digikey.
Nov 29, 2009 | NEC LT20 Multimedia Projector
Clean Filter - NEC VT700 projector
Need to go into the menu and find the option to reset. Choose the "reset filter hours" option.---Rick
Sep 04, 2009 | NEC VT700 Projector
NEC VT 440 Projector noise
The unit needs to be opened and have the fan checked. If it is out of warranty and you are capable you should be able to access the fan quite easily. It may be rubbing against something or it may have contaminants inside and needs to be replaced.
Jan 25, 2009 | NEC VT47 Multimedia Projector
Status Light Flashes
Hi kmarie01
This is most probably a faulty Ballast ( lamp's powersupply ) that will have to be replaced before the Projector will come on at all.
May 13, 2008 | NEC MultiSync MT840 Multimedia Projector
NEC MT1055 Will not power up
Hi there
This sounds like a faulty Ballast ( lamp's power supply ) It will unfortunately need repair or replacement.
Mar 25, 2008 | NEC MT850, MT1050, MT1055, MT1056...
26 people viewed this question
Top NEC Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Joe Goldman
Joe Goldman
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
