SOURCE: Musty smelling washing machine
www.smellywasher.com you can order here to take care of that problem!
SOURCE: My Maytag Neptune smells very musty. I have used
This is gunk build up under the agitator and/or the drain area under the drum. It needs to come apart...
SOURCE: I have lost manual can you run something thru a
Hi The smell usually comes
when the washer is unable to drain water completely, you can run your washer at
its hottest temperature setting with 1 cup of vinegar inside the unit. After
this take off the bottom front panel and clean it completely, also clean the
drain hose and drain pump filter, the smell should disappear after doing all
this. Hope this helps...please post back for further assistance. Daniel
Hi
Daniel
