Question about Pool & Spa
Can you use a spa with a European plug in the UK? We have an adaptor but keep getting 6CF message
Posted by Julia Peachey on
  • Anonymous Feb 19, 2021
    no spa told, make and model nor country sold.
    no UK plug shown. Try to call an electrical licensed.
Real Cool
    Top Expert:
  • 33,520 Answers
Please check out this link: https://www.fixya.com/support/t26994161-lay_z_spa_6cf_error_code
Posted on Feb 18, 2021
Lay z spa 6cf error code
This is the REAL answer if you see the 6cf error code it's to do with the plug.
I had the error code 6cf and it took hours to work out what was wrong and it was so simple... the pump unit needs to be plugged straight into the mains plug. Wont go away or work of your using an extension cable.
After I plugged it into the mains plug directly error code disappeared fully working.
Hope this helps people and saves them hours of dread thinking they bought a broken unit.
Jun 02, 2018 | Pool & Spa
I just moved to France and brought my Juki TL-2010Q from the USA. I plugged it in with a European adaptor and it blew the fuse? Is it fixable? Where do I get a replacement fuse? Thank you! Suzanne
Did you mean an 'adaptor' (as in two-pin to 3-pin) or a transformer ?
It is a DIFFERENT electrical system in Europe to the USA.
The USA is 110v and Europe is 240 or 220v. The machine is
probably burned out. You would need to take it to a dealer to be checked. You can ONLY use USA electrical equipment with a TRANSFORMER, so that it can function on the different European electrical system. Good luck !
Sep 12, 2016 | Juki Sewing Machines
I know there is a difference in voltage between here and Europe. What I can't find on my photive is which voltage it uses so I don't know whether I should use a transformer or just an adaptor when I p
Your device takes a standard Micro USB that charges at a voltage of 5 Volts, any plug from a charger or computer that has a USB port will provide the correct voltage for charging this device.
When going to Europe you can use this product Travel Adaptor Plug Worldwide European Visitor To Uk or to change
Pack of 5 UK to EU Travel Adaptors Amazon co uk Electronics to change the plug for you USB plug, depending if you are from the UK or US.
Sep 09, 2014 | Cameras
What is error code 6cf on my lay-z-spa
How can i solve this problem?
Jul 27, 2012 | Pool & Spa
Norwegian ac adaptor from NES on UK SNES
The adaptor SHOULD work, seeing as European SNES's use the same voltage. If you use an adaptor with a different voltage, you might need a transformer or voltage converter.
Nov 03, 2011 | Nintendo Super NES Console
I have nuvi 250 which needs the UK update. It has a memory card slot on the side. By using the card will I lose the European maps or does it just overide the UK maps
If it already has the European map then updating the European map will also update the UK map since the UK is part of the European map. You can get more details of how to update your map at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
Jun 11, 2011 | Garmin GPS
Been given an AH300 with tuner and cd player. However I am in Canada and the unit came from the UK. Will any 240 to 120 plug adaptor do? Will be tuner be compatible here in Canada? Thank you Mike
Yes to the first question. In the UK, they use the same power ratings, just different plugs (went there for my brother's wedding. Had to buy an adapter for my cell phone charger).
As for the tuner, they run on different frequency intervals there, but you should be able to pick up a few stations, since European and North American frequency intervals overlap at numerous points.
If you want to pick up all of the stations, check to see if this unit has an aux in, and run just a tuner head into this unit.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 12, 2011 | Teac A-H300 Amplifier
Layz spa keeps going off says on readout 6cf.heater is fine pump everything else is ok cheers kevin
You have a problem with the RCD (residual-current device). This is the part of the plug that you have to push reset on before a current will flow. You can repair this by buying a new RCD plug and rewiring it or if you already have an RCD socket adaptor for another appliance, you can just cut of the plug on the pod/ pump and rewire it into a rubber plug and then plug this into the RCD adaptor and the lay z spa should no longer cut out. The RCD is important because you do not want to blow the unit inside.
I hope this helps, If you need more assistance, please ask.
Sep 30, 2009 | Pool & Spa
Re: hannspree 37 inch
i have got a humax 32"lcd idtv.
my sky remote does not find it can i get a code to put in thank"s
Jun 07, 2008 | Televison & Video
Pool & Spa Logo
27 people viewed this question
Top Pool & Spa Experts
john h
David Spradling
David Spradling
Tom Chichester
Are you a Pool and Spa Expert? Answer questions, earn points and help others
