Radio Communications Logo
Question about Radio Communications
I have a rci 2980 I was told it will do 50watts but with the variable power turned all the way up I'm barely getting 20watts. Does anyone know the number of the pod to turn the power up. (Need help please thank you very much)
Posted by Daniel Robinson on
  • Radio Commun... Master
  • 19,127 Answers
Probably has MOSFET transistors in it and you cannot do a lot with those and they are easy to blow out if you set them wrong.
Posted on Jan 06, 2022
5 Related Answers
Anonymous
SOURCE: radio has no modulation
probably a final is out.
Posted on Feb 03, 2009
Anonymous
  • 39 Answers
SOURCE: need wireing diagram for a rci 2980 to tug8 mic
Here is what I have: If the Tug 8 is a 4 wire cable,1/shield 2/white 3/red 4/black 5/N/C 6/N/C
If the TUG 8 is 6 wire cable,1/shield & blue 2/white 3/red 4/black 5/N/C 6/N/C .The reason I gave two diagrams is I can never remember if the 8 or the 9 is 4 wire cable.Also if your radio keys up when you plug mic in reverse the black and red.Good Luck and take care!
Posted on Feb 25, 2009
Anonymous
  • 219 Answers
SOURCE: does anyone know the pod too turn for lowering the watts
You have to adjust the high key first so make sure you're rf power is on high, hope you have a meter set it on the 20 watt scale, key up and turn vr 13
located in back of radio infront of where you're coax connector is until it keys around 12 watts, thats where most connex 33hp should be set,now go to low power and key adjust vr 16 right net to the otherone down to about 3 watts, now you can drive a liners. Mod is Vr 2 right below them two. whistle in mic and turn to get the mod you want.
Posted on Nov 21, 2009
kb8dns
Rod Wallberg
  • 494 Answers
SOURCE: RCI-2980 NO MODULATION
Microphones are the most handled object with a CB radio and this is where it is most likely to find the problems. Basically a Galaxy radio in a base station box, and 3 out of ten develop problems, mostly power supply problems.
I would suspect the mic first. Best way is to use a different mic and see if the problem goes away. Next try the radio on an external DC supply or battery. Let me know what happens from there..... [email protected]
Posted on Feb 20, 2010
Anonymous
  • 5 Answers
SOURCE: Does anyone know how to open up mod on a galaxy
They are pots. Not pods. I hope you blow up your radio. CBers. Wanna be a big boy. Get a license.
Posted on Sep 13, 2010
I need to know how to do a swing kit on my rci 2980. Please help thanks
GOOGLE LINK BELOW
https://www.google.com/search?q=swing+kit+on+my+rci+2980&oq=swing+kit+on+my+rci+2980&aqs=chrome..69i57&sourceid=chrome&ie=UTF-8
How do i go about fixing the receive in the RCI 2980.It has some receive but it is low.What might be causing the problem.
you are not qualified if you have to ask this question. Take it to a tech and let them straighten it out for you.
3answers
1helpful
I got a rci-2960f cb radio does any body know anything about this radio it has a big heat ink on the botton does any body know wat watts it was putting out
The radio has a heat sink as it has a amp built into it--about 100 watts maximum output---get someone with a DUMMY load and watt meter and see what it is putting out power wise--Most of the RCI have a variable control on the front for power output.
1helpful
The s-meter goes down scale when I am modulating. What causes this? THIS IS ON A RCI 2980 RADIO
the reason i saked is that if you turn the power all the way up it tends to reverse modulate. this happens because the power is using all the transmit voltage for the final and the modulation circuit is trying to use as much as it can so the radio is most likly out of alignment and needs to be realigned. its not that hard if you have the service manual and the correct equipment. i have a factory authorized shop and we do alot of realignments due to the cb shops tweaking the 10 meter radios.
7helpful
3answers
RCI 2980 power adjust problem
VR16 is not the low power adjustment, it's the CW Tone.
As far as I can tell, there is no low power adjust.
Try a different resistance pot for the RF Power.
Radio has no modulation
Open Questions:
Top Radio Communications Experts
Marvin
Marvin
Tom Chichester
Are you a Radio Communication Expert? Answer questions, earn points and help others
