SOURCE: Electric baseboard heater
You need a meter, it will be hard without this! If you have 220v in the wall, then think of it like this; each wire is 120v. Test to each other, you get 220v. The thermostat is a double pole, you said. So think of it like this, its an adjustable temperature controlled switch that lets electricity through at the temp. you set it at. If you have 120v from one wire connected to one end of the element, and the other 120v connected to the other end of the element, then it will work. DO NOT CONNECT THE 120V TOGETHER. IT MUST GO THROUGH THE ELEMENT FIRST. The thermostat should be between the power from the wall and the element, to control the temperature.
SOURCE: electric baseboard heater hums while running
is a 60 cycle hum, resonating with the power. check screws that mount it nothing to really worry about
SOURCE: how far off the floor do i install hot water baseboard heaters
When you install the baseboard heater make sure the bottom part which is the all thing must sit over the floor and touch the tiles or carpet and use 2 or 3 wood screw against the wall. That is it and do not put any kind of paper or cotton or material things above the cover. Beside that you are ok and it is not like an electric wall heater.
SOURCE: Fahrenheat electric baseboard heaters are not safe for children
A few companies sell child-proof covers that prevent little fingers and small objects from getting into the radiators. Try searching Child-safe baseboard heater covers in a google search or PexSupply.com.... we use them in daycare centers.
SOURCE: connecting 240 volt singer baseboard heater
Need front grill for singer model WJA-12 wall heater Cat # 9756-A
single phase 60 HZ
240 volts 5.2 Amps
1250 Watts
Where can I find it?
