Question about Kenmore Kitchen Ranges
I have a 970c633621 Kenmore range and my convection fan does not work anymore how do I troubleshoot.
Posted by Elmer Zander on
David Spradling
    Top Expert:
  • Kenmore Master
  • 12,034 Answers
If voltage from switch see if fusible link up in hood if not if voltage to motor bad motor
Posted on Apr 09, 2021
5 Related Answers
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Convection oven no longer works
Could be the fan trying to start, ,if there is a removable cover in the back of the oven, remove it and see if the fan is free to spin, could be a tight bearing , or it could be stuck with a build up of grease.
Posted on Jan 02, 2009
cactus bob
BOB BROWER
  • 267 Answers
SOURCE: I have a Kenmore Elite Electric Range and when I
this is a super common problem for all convection ovens . your motor is going bad . you can replace it yourself as long as your handy . parts can come from searsparts .com or any appliance parts store . any repair person you call to do the job should have no problem . these motors go bad every 10 years or so , or more if you use it a lot ..........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 17, 2009
Anonymous
  • 619 Answers
SOURCE: Lower element in Kenmore electric range does not work.
remove and take to appliance shop and they will match up for you. Make sure power is off before doing.
Posted on Feb 02, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: I have a Kenmore convection
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: Kenmore Convection free standing range F2
Actuall because Sears/Kenmore has so many manufacturers we really need you model number to translate your F2 code to the manufacturer. However.... most F2 Codes are pretty common and all point to a bad temp sensor. Most temp sensors read 1,000 to 1,100 Ohms at 70 Deg F if they are functioning. See this link and note the very bottom sensor by GE will read differently. http://www.applianceaid.com/oven_temp_sensors_help.html
You also did not mention if this was a gas or electric range. If you need more assistance, please provide a model; number and I will help you.
Kelly
Kenmore elite electric just delivered
It does that to speed up the pre-heating process.
Feb 09, 2016 | Kenmore Kitchen Ranges
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Will a plain fan convection/microwave ROAST/BAKE as well as a "true" convection that has an extra heating element and fan convection/microwave
Most likely the Kenmore is actually made by Sharp. Most of the combination microwave/convection ovens are. I have one with a "Wolf" name on it, and it roasts/bakes very well.
Apr 07, 2015 | Kenmore Kitchen Ranges
I HAVE A KENMORE RANGE MD:970-339337 THE CONVECTION FAN MOTOR WORKS INTERMITTENTLY REPLACED THE FAN MOTOR AND THE BOARD STILL THE SAME PROBLEM
By now you have spent a great deal on replacement parts, time, and effort. Unless you are an expert on servicing the range; I suggest using the Sears professionals and get the job done right the first time around.
Dec 19, 2014 | Kenmore Kitchen Ranges
How to change the fuses
Hi Steve,
I have 2 videos for you and hope it helps you on how to resolve it.
May 08, 2014 | Kenmore 5.7 cu. ft. Electric Range w/ True...
The convection fan does not work anymore in any of the following situations: Convect bake, roast bake or quick preheat. What could be the cause? Can we get the electrical schematic for this...
This is your convection motor that's gone out. If you will call or email us, we;ll be sure to send the correct motor along with the schematic for your Jenn-Air range. This is an easy problem to solve so please get in touch with us soon so you can get your oven running right again.Remember...Thanksgiving is just around the corner, so lets get you cooling again real soon. We hope to hear back from you real soon,
Sep 29, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Kenmore elite slide in range model 790-4101
how do you take the top off this LG LRG30357ST i cant get a tool small enough to fit the back right burrned orifes to convert it to lpg
Jan 20, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Fan for convection oven not working
Maybe you could throw out the oven and buy a new fridge
Feb 02, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchen Ranges Logo
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Marvin
Marvin
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
