Sharp Mx-2610n Color Copier, Printer, Scanner Logo
Question about Sharp Mx-2610n Color Copier, Printer, Scanner
My MX 2610 when connected to a computer it will not pop up showing new hardware found after installing it, it will not print Can anybody assist?
Posted by musa on
  • The Spaminator
    The Spaminator Feb 19, 2021
    Hi musa , we want to help you with your question, but weneed more information from you. Can you please add details in the comment box?
    did you download the correct printer driver for the operating system and printer model ?
    suggest you visit https://global.sharp/restricted/products...
    and see if there is a printer driver for your set up
ADMIN Andrew
    Top Expert:
  • Sharp Master
  • 50,634 Answers
You need the FULL Software Package, not just the Windows Driver. Plug and Play is unlikely to work. It is here;
MFPs - MX-2610 - Drivers and Utilities
https://business.sharpusa.com/Product-Downloads
Posted on Apr 21, 2021
5 Related Answers
Anonymous
SOURCE: Found New Hardware MTP Device. Pop-Up
Get A Mac!
Posted on Nov 30, 2008
Anonymous
SOURCE: New hardware might not work properly
Right guys, found the sollution:
Right click on My Computer, Choose Properties from the drop down list, then click on Device Manager.
Down the list, there will be Universal Serial Bus (USB) controlers. If this selection isnt expanded already, click on the + icon next to it.
In the list that pops down, there will be an entry called IPod and it will have a yellow question mark on it. Right click on this, choose properties and then click on update drivers. Follow the install wizard and then voila! It will be installed.
Have fun guys!
Posted on Feb 01, 2009
Anonymous
  • 1689 Answers
SOURCE: lexmark z25 printer light keeps blinking, will not print
hi alisaguilor,
what is the operating system of your computer? as per the actual modem, this cannot run on vista. but if it is windows XP, you may try uninstalling and reinstalling the printer driver using the drivers from this link.
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:337:0:0
just select your operating system. hope this helps.
regards,
voodoo
Posted on Apr 19, 2009
Anonymous
  • 150 Answers
SOURCE: I bought a MP4 player, china made.
hey try to Reset with a pin ... there will be a small Pin hole in ur chinese mp3 player
Posted on Sep 02, 2009
Anonymous
SOURCE: Cannot connect Coby MP715 4gb to computer
I had this problem as well with xp, I tried a different usb port and it worked right away.
Joy
Posted on Sep 09, 2009
How to install versajette M400 printer
To install your printer, connect the printer to the computer or laptop usint the cable that links it up.
The computer would see it as a new hardware, you can install it from the bar that shows up from the tab side, or you can also go to the computers control panel, select add new hardware, then a list of new hardware found will appear, then you select the versajette m400 printer, and install the drivers.
After doing this, you can now start printing with your printer.
Take care
Suddenly, my hp printer won't print. I use
try to remove everything from printer that connect to you computer, from you pc remove driver restart and connect your printer it must be a pop up that found new hardware to you computer. in not then you computer not detect that printer. try to replace printer cable. if still not work tr to connect your printer to other computer to conclude where the problem. from printer or from you computer. please give feedback for next trouble shooting.
When I unplug my 2610 printer to move it then plug it back in, it does not work. Twice before this happened and somehow I fixed it when it went to the print wizard. This time, I cannot fix it. I downloaded...
First disconnect the printers USB cable from the PC. Go to the control panel and open add or remove programs. Find the installed software for your 2610 printer and select to uninstall the software. When completed restart the PC. Install the latest software for your printer from HP.com and during the installation it should prompt you when its time to connect the printer. When prompted, connect the USB cable from the printer to the PC and power up the printer. You should see a message indicating that your computer has found new hardware and is installing the necessary software to complete the installation. Call HP support if these steps don't resolve the issue.
Unable to connect Nokia 3120 Classic with PC
Souns like you need to reinstall the Nokia software. Just pop in the CD and run the setup wizard again. Reboot computer when you are done and try connecting your phone.
If you need further assistance, let me know.
Regards,
Jedi
Cannot reinstall
I had a friend that had this problem.  Disconnect the printer and shut it off.  Go to add/remove programs and remove all software related with it.  Restart your computer.  Put the cd in the drive and install all the software.  DO NOT connect the printer until the software tells you to or says that it can not find the printer.  First plug the USB to the printer and to your computer.  Then press the power button on the printer.  If a found new hardware box pops up, press cancel.  Continue with installing the software.  Restart your computer when you are done.  This worked for my friend.  People do make the common mistake of not unplugging the printer when reinstalling software.  Hope it helps.
HP 4350 is not being seen by my computer via USB
Just buy connector which is sensitive with low resistance.
2610 won't print
By self-test, I assume you are doing that manually on the printer. drivers downloaded/installed? right click on my computer, left click on properties, click on hardware, and then click on device manager. is there a yellow question mark by print drivers? If so, then need to load them from the internet or from your installation disk.
Datamax M-4208 shows ready but does not print
I belive that, PC can detect the Printer and the only problem, the drivers are unabled to route the print queue and that creates a problem.
If your OS is XP/Vista/2000, try the below steps.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall. ((IMPORTANT NOTE:WE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for what location says, Eg -LOCATION : Datamax M 4200)).
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
1helpful
2answers
Problem installing the driver
Mine did the same thing - just ignore it and click ok - it will work believe me - just do it and it'll work.
Top Sharp Office Equipment & Supplies Experts
George Mclaughlin
Cosmas Matanda
Cosmas Matanda
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
