Question about Welding Tools
Wire on deltaweld 302 is always hot - Welding Tools
Posted by Jesse Simon on
1 Related Answer
luis_david
David Soto
  • 414 Answers
SOURCE: i have miller deltaweld 302 lead stays hot all
Hi:
The problem could reside on the contactor, this part due to the heat and constant contact (that is the noice you hear everytime you strike an arc) sometimes it remains close. Check your owners manual and it is the numbered 21 on the part list.
Good luck
Posted on Jul 13, 2011
Wiring new electric plug on cable end
The green wire is always connected to the ground lug which almost always has a green screw in it. I goes on the long rounded, u shape or L shaped post at the end of the plug.
Jan 29, 2014 | Miller Electric Mfg Co 903376 Deltaweld...
I have miller deltaweld 302 lead stays hot all time what is th problem
Hi:
Good luck
Jul 12, 2011 | Miller Electric Manufacturing Electric...
Stringy welds
Turn the heat higher and the wire speed lower and you will get better welds...
try to turn the heat up first....
heatman101
Mar 04, 2011 | Miller Electric Mfg Co 903394 Deltaweld...
How i can use wire feer x-tyrem with a cp-302 welder
Hi:
An easy one: Connect your Suitcase X-treme 8 or 12 VS (volts sensing) as follows:
Weld Cable (+) To Feeder lead cable.
Work Cable ( - ) To Workpiece Weld cable and work cable connections to power source (DCEN/DCEP) are dependant on wire type.
Since feeder is not polarity sensitive, there is no need for an electrode polarity switch.
Voltage Sensing Clamp Connect voltage sensing clamp to
workpiece.
Gas Hose to regulator.
Gas Cylinder to regulator.
Use of shielding gas is dependant on wire type.
You are all set up to weld.
If this was useful. Please vote.
Feb 22, 2011 | Miller Electric Mfg Co 903376 Deltaweld...
How do you hook a miller s-22p8 wire feeder to a lincoln ranger 10,000 plus engine driven welder?
you can't, the S-22P8 it's not a volt sensing wire feeder, it requires 24V or 115 with an adapter. FOr CV machines only.
Dec 08, 2010 | Miller Electric Mfg Co 903376 Deltaweld...
. Hello! I have a millermatic 251 and a 252,
Flux core wires will run on reverse polarity (gorund +), for solid core wires you need straight polarity (ground clamp at negative ). That will take care of the problem.
Nov 21, 2010 | Miller Electric Mfg Co 903376 Deltaweld...
What size breaker and wire is required to operate the miller 452
You can tell by the plug configuration. The shape of the prongs. No Manual?
May 18, 2010 | Miller Electric Mfg Co 903394 Deltaweld...
CP 302 wlder
Trigger the wirefeeder while listening for the contactor on the CP302 to close, if it does start looking for loose, bad or missing ground connections to the work, then look for the power connection from the CP302 to the wirefeeder to be bad. If the CP302 contactor doesn't close look at the control cable between the wirefeeder and the CP302, try a different one if possible. If you hear the contactor close, and everything else is good, check the voltage at the CP302 output terminals to see if you may have a bad contactor.
Oct 29, 2008 | Miller Electric Mfg Co 903376 Deltaweld...
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
ray gallant
Are you a Welding Tool Expert? Answer questions, earn points and help others
