Question about Xerox Phaser Office Equipment & Supplies
I try to print from the printer by select print a configuration or settings report printer not print Go to "hidden service" menu run diagnostic and got the message :" Fatal Fault Encountered Controller in Spin Loop Power down Required" Please tell me what to do . Thank you
WE CAN NOT AS WE ARE NOT THE MANUFACTURER OR EVEN ASSOCIATED WITH THEM
Posted on Apr 23, 2021
SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Posted on Nov 23, 2007
SOURCE: Technical Black Imaging Unit Replaced,Error message still shows
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Posted on Dec 04, 2008
SOURCE: Xerox Phaser 7760 Prints White Lines Diagonally Across Page
That is normally caused by a bad developer housing.
Posted on Jul 16, 2009
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve
imaging unit recognition problems, link below.
http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB
Usually this problem only occurs if the NVRAM has been reset or the engine
board has been replaced without backing up the NVRAM.
You can download the snippet to your printer through Centreware or by
downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
SOURCE: Xerox Phaser 7760 prints white diagonal lines
Are the white lines in one color or all colors? If it is just one color you should try cleaning the laser window. Open the front cover and in the cover there should be a cleaning wand. Remove the waste cartridge and use the cleaning wand to clean the laser windows located behind the waste cartridge.
Posted on Jul 18, 2011
