Cameras Logo
Question about Rayovac Cameras
My zd8612is drains the batteries I used energized rechargeable and rayovac crv3 battery packs and it will come on and go right back off
Posted by Jess pennington on
john h
    Top Expert:
  • Rayovac Master
  • 27,461 Answers
Need to test for short
Posted on Apr 21, 2021
5 Related Answers
Anonymous
  • 10594 Answers
SOURCE: Camera keeps shutting off.
Please use Sony Cyber-shot batteries for DSC-H2 model camera.
Posted on Nov 18, 2008
eradiostore
eradiostore
  • 1667 Answers
SOURCE: How to charge battery in Motorola Talkabout Distance DPS
You can obtain a wall adapter style charger for your radio at your local Motorola dealer, or online at http://www.eradiostore.com/cart/index.php?target=products&mode=search&subcats=Y&type=extended&avail=Y&pshort=Y&pfull=Y&pname=Y&epcode=Y&q=htn8232
Sidenote: The rechargeable battery is good for about 2 to 3 years. You can tell the age of your battery by looking at the date code on the back of the battery above the stop sign. The first number is the year, the next two numbers are the week of the year. 915 would be 2009 the 15th week. (Or if very old it could be 1999 the 15th week.) A good battery, when charged will go an 8-10 hour day.
Keep both of your charge trays, replacements for these are no longer available.
Posted on Apr 12, 2009
Anonymous
SOURCE: Rolleiflex 3003 Battery Pack
where i can find the battery back, for 3003 the batteries can refield
Posted on Jul 09, 2009
Anonymous
  • 33 Answers
SOURCE: Recharged NIMH batteries (1.4V) are too low in voltage for Wii
#1 rule for batteries do not overcharge/overvolt, dispose of in fire or throw at your cat unless you like fireworks.
you will need new batteries for your wii, i have a couple of rechargeable wii battery packs that i bought from EB Games they work fine, they hold charge, and they save batteries, my fave part is where you buy 3-4 of them and you have two charging while you use the other two.
also a small tip, the nintendo wii is very anal about voltages, but a pocket flashlight isn't. you can take batteries that refuse to work in your wii and put them in your flashlight.
Posted on Sep 10, 2009
Megasom
  • 699 Answers
SOURCE: Logitech MX1000 Laser Cordless Mouse, I replaced
Li-Ion battery and NiMh battery have completely different charging requirements! Li-Ion battery has much stricter charging requirement and the regulator is normally design to trickle charge at 0.1 Current rating @ 4.2V and then completely shut down.
WARNING: if you use a Ni-Mh charger on a Li-Ion battery, then it will erupt and even explode and catch fire!
Bottom line is that the rescued Li-ion regulator is not designed for your Ni-Mh pack and you will never get a full charge with it and you will need a completely different regulator board: you are better off putting in a suitably sized Li-Ion battery with inbuilt regulator but with higher current rating if possible.
Hope it helps! Let me know how you go.
Posted on Jan 05, 2010
1helpful
What batteries can i use instead of smashing batteries? Duracell ?
That camera takes lithium batteries. Duracell are DL123. Others are Energizer CR123 or Rayovac CR123A. The 123 is the key here. Other makers of lithium disposable batteries will use different letters, but the 123 is what you're looking for. They should still be available at Walmart etc. Panasonic CR 123APA 1B CR 123A Photo Lithium Battery Retail Pack Single
2answers
I have this camera and it has new batters but it wont turn on.... WHAT DO I DO
The CRV3 lithium battery, is non rechargable. It must be lithium, because lithium has a higher voltage than other batteries.
Not sure if you can put the batteries the wrong way around in the camera but be sure you did put them in correct. Check if the contacts in the camera are clean and shiny.
Rayovac 3Led Crank Flashlight
You will have to take it apart and replace the battery pack. They use the same as a portable house phone of a remote. Get lithium rechargeable.
1helpful
Can i use regular batteries and not rechargeable batteries on my kodak cx4310?
Yes, 2 AA batteries. Just insert them correctly.
They don't last as long as the CRV3 lithium battery pack though
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} I bought the CRV3 battery and charger at Radio Shack and love it.
Bought it 3 years ago, still using the same battery after taking 1,000's of pics. I also keep a pair of regular AA's as a back up when I'm away from home
Installed new batteries and the camera will not turn on. The camera has been sitting up for 6 mo. with no use. We used energizer lithium batteries.
Try using recomended batteries:
optional KODAK EASYSHARE Docks with 1 KODAK Ni-MH Rechargeable Digital Camera Battery KAA2HR; 2 Ni-MH batteries AA, 2 lithium batteries AA; 1 KODAK Lithium Digital Camera Battery CRV3; KODAK Ni-MH 2100mAh Battery Pack, KODAK Digital Camera Battery AA (ZR6); KODAK Alkaline Digital Camera Batteries AA; 3 volt DC input AC adapter
You can even contact Kodak direct and they will send you a free CRV3 battery to test with.
(http://graphics.kodak.com/docimaging/US/en/Landing_Page/ServiceSupportContacts/index.htm)
2answers
I've been using Olympus 550 UZ camera for over a year now. I am facing problem with the life of battery though. Tried Energizer and Duracel batteries. 10-15photos and the battery is drained down. Is there...
Switch from alkaline batteries to pre-charged Nickel Metal-hydride (NiMH).
My best experience is with these batteries:
#1. RayoVac (pre-charged)
#2. Kodak (pre-charged)
#3 Energizer (rechargeable)
Find them at WalMart or online
"pre-charged" are new technology rechargeable batteries. They are GREAT! They outlast alkaline at least 15 times per charge.
Battery life of kodak easy share is 2 pictures ... if that
Please check what type of batteries are these.
Z1085 will only work with LITHIUM AA's, Lithium CRV3 (you have to make sure it's not Ni-mh crv3) and a rechargeable KLIC 8000 Lithium-ion battery pack (the blue one). It will not work with any other type of rechargeable battery but KLIC 8000. If you're trying to use ni-mh rechargeables, it will really not work.
2answers
Beeping
no problem. your rechargable is not strong enough for this camera. i use rayovac rechargeable from wal-mart and the batteries have to charge for two full days and make sure the light on the charger is off before removing the batteries from the charger. then put them in the camera and it will work perfectly. your batteries aren't strong enough for the camera. go out and get some energizers made just for digitals. they last forever but, they'll do until you get your rayovac rechargeable recharged. and coming right out of the pack they are not charged give it 48 hours and they'll last weeks.
Charging the battery
your camera can use any variety of batterys-aa recharg-crv3-aa lithium etc-what i would try is a different version of bats before just replacing the camera-cameras tend to develop internal shorts inside which can drain bats down even when not in use-try energizer lithiums as experiment-i get 200-400 pics on a single set-they are not rechargable-if this doesn't slove prob i would upgrade camera-good luck!
9helpful
6answers
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Top Rayovac Cameras Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Rayovac Camera Expert? Answer questions, earn points and help others
