Televison & Video Logo
Question about LG Televison & Video
LG42LN5700 flat screen TV. Why does it have a black screen?
Replaced the LEDs and power board which has the LED controller built-in. I do see a picture behind the black screen.
Posted by Kath M on
Aron
    Top Expert:
  • LG Master
  • 2,325 Answers
There is a problem with backlight and your LCD screen too on your TV. Change the picture mode to Standard and then make sure that your backlight setting is at the lowest. Unplugged the power cord from your t.v and plugged it back in and see if that fixes the issue. It could be the fact that your TV has died on you and you should buy a new TV. The newer TV's seem to be not lasting as long like their CRT components do on the other hand.
Posted on Apr 22, 2021
5 Related Answers
Anonymous
  • 138 Answers
SOURCE: 42PF5321D/37
Measure the connector from the logic board to the power supply the second pin from the left it will say Vs_ On if the set has 3.1 volts the problem is the SSB or the logic board. On the logic board there should be a solid led and a flashing led that shown that data id flowing and the problem is the SSB. The SSB is easy to replace just remember what you tokk loose and from where. You probely will save money that way. If the set is in warranty or just out of warranty contact Philips 1-888-744-5477 and see what they can do first.
Posted on Aug 20, 2008
Anonymous
  • 71 Answers
SOURCE: 42inch sanyo vizon flat screen tv bought 18 months
2000 $ ???
Posted on Mar 05, 2009
usavacuum
  • 57 Answers
SOURCE: Hoover Savvy U8174-900, replacement circuit board LED/Brush Motor
clear1x1.gif Hoover Switch & Circuit Board with Handle for Hoover Savy & Bagless
Follow this link to USAVACUUM.COM
www.usavacuum.com/category-s/63.htm
Posted on Feb 21, 2010
Anonymous
SOURCE: Clicking relay no picture no audio no power light red or blue
here is the schematics http://www.scribd.com/doc/33598674/Philips-42mf231d-Chassis-Tpe1-0u-Pa
Posted on Aug 14, 2010
Anonymous
  • 10594 Answers
SOURCE: STANDBY LED LIT AT
All three lights blinking on tv shows any one of following problems
1 - Color wheel is defective
2 - Lamp ballast is defective
3 - DMD board is defective
Does lamp turns On for moment before tv shuts off (you can observe it at rear of tv) that will confirm that either color wheel or any fan in tv is not running.
You should have service manual copy of tv to troubleshoot it.
Let me know if you have additional question.
Thanks.
Posted on Sep 10, 2010
How do I fix an LG42LN5700 flat screen TV that has a black screen?
Try to unplug the external component if possible for about 30 seconds and disconnect the HDMI cable from the TV and move it to a different port and plug the device back in and change the TV to the new input to see if the problem still occurs.
Samsung led tv gets power but see no picture. sometimes have heard sound when toggling through inputs. I replaced the T-con Board and the TV worked fine for a while. Now I'm not sure what to do.
LG LED TV has no picture (black screen) but still has sound - can ...
www.tomsguide.com/answers/id-2660992/led-picture-black-screen-sound-fixed.html
Feb 9, 2017 - My 32' LG LED TV has suddenly lost picture! The sound is alright but the screen is pitch black. ... Then completely black but with audio. ... I'm really hoping if I do the right research Ican fix this tv for my husband. .... Take the screen off hit power and watch LEDs if any don't flash its LEDs if they all flash its ..
Hitachi led tv no picture but has sound
hi, the led or leds in the panel may shorted, thanks
shaun
My LG 47LN5400-UA flatscreen has a black screen, everything works fine except black screen, when I shine flashlight on screen I can see full color picture, I have replaced the power supply/LED board.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board
2answers
Audio is fine. Why did picture suddenly go black?
The board that controls the back light for the screen is called an inverter board. Sometimes, depending on the model , the inverter is combined with the power supply board. Go here to find the parts :www.shopjimmy.com
How do i test a backlight for a led tv
Testing TV Backlight LEDs - YouTube
? 4:44
https://www.youtube.com/watch?v=eEJoPCa7Kt0
Jan 24, 2015 - Uploaded by swappart.com
... explaining easy way to test individual LEDs on a strip from aTV backlight. ... Sharp LC-60LE820UN TV - LED Strip Testing - Long Version ...
IT02 - How to Test LED Backlight - YouTube
? 0:55
https://www.youtube.com/watch?v=YmSI2N6BGPA
May 20, 2011 - Uploaded by LCDPARTS
How to use IT02 to test Laptop screen LED backlight.
LST04-TV, How to test LED TV screen - YouTube
1helpful
Lg 50LN400-ua is the led driver on the power board
The power supply has the LED driver circuitry built in. I would suggest to measure the voltages without the LEDs connected to the power supply, if the voltages are present without the LEDs connected then you have a defective LEDs strips inside the panel. If the voltage is low or absent, the power supply should be replaced.
2helpful
2answers
LG 50ln5200-ub led TV . Has no picture but great sound . What is the problem ? I did the flashlight test and can see the faint picture which tells me the backlighting is out . This tv model is a Black...
usually bad power supply, Where did you source your part? return/exchange it. Bad LEDs/ possible but not as likely, Tcon working if you can see images with flashlight. You must also have backlight on signal from main board ,check for 3 to 5v on labeled connecter on power supply. UPDATE---47" & 50" LN series. This model has had LED problems if your TV acts as described by Mr. Hughes in is answer to this problem you have bad LEDs
Marvin
Marvin
Muzahura Frank
