Nope, all sets NEED a remote control. Only basic functions from the set. Just buy a new remote SPECIFICALLY for that set
Olevia TV, Video & Home Audio Remote Controls for sale ' eBay
www.ebay.ca > Olevia-TV-Video-Home-Audio-Remote...
Results 1 - 35 of 35 - GENUINE OLEVIA ?LEVIA RC-LTU UNIVERSAL REMOTE 537-B11 537-B12 537H 542-B11. C $43.40. Free shipping. or Best Offer ...
Customer reviews: Universal Remote Control Fit ... - Amazon.com
www.amazon.com > product-reviews
Find helpful customer reviews and review ratings for Universal Remote Control Fit for Olevia RC-LTU 2500005701 537-B11 537-B12 537H 542-B11 542I 742I ...
olevia tv remote control - Amazon.com
www.amazon.com > olevia-tv-remote-control > k=olevi...
Results 1 - 16 of 118 - New RC-LTL Replacement Remote Control fit for Olevia 5 Series LCD HDTV 526 527 532 537 542 527S11 527-S11 527-S12 527V 532B1 ...
SOURCE: Re: Can't change from Video
You will need the remote to do this. If you can't find the remote get a universal remote with a video or input button on it. The other set may not be the same model and has different features.
SOURCE: lg lcd tv remote code
HI,
BUY A NEW REMOTE FROM E-BAY OR PARTSTORE.COM,TRY A UNIVERSAL ONE IF STILL DOESN'T WORK TV INTERNAL IR INTERNAL RECEIVER IS FAULTY,THANKS.
SOURCE: olevia 26" flat screen
screen suddenly shut off. blue light in the right hand corner stays on but there is no picture
SOURCE: Olevia 42"
Olevia LCD 542I - Had the same issue for a week until the tv would not turn on anymore, after several attempts it came back on. A few days later the tv turned off then only the standby light was on, then lost the standby light as well. After researching the problem it could be in two areas, either the power supply or main board. Removed the back and found the power supply had several capacitors that were bulging on the top and appeared the fluid was leaking, all signs of a failed part, removed the PS and replaced four capacitorst that had shown some issues. If you can removed the PS and check for a number on the board, mine was FSP271-4F02, and find someone who has some electronic circuit capablilty, the issue may be resolved at a fraction on the cost of a new power supply.
SOURCE: Power on problem for My Syntax Olevia LCD TV 23"
I have a 24" Olevia LCD TV. Same symptoms (Stdby LED is on, press power and it flashes off, then back on). The USB cable to the Service Port also worked. But being of sound technical mind, I figured this means that the PC is supplying the +5v to the circuit. What I did was disassebled the TV, carefully disconnected all the cables, and opened it up to reveal the circuitry. I looked over the circuit and noticed the 1000uf/16v capacitor at position CS21 was failed and bulging. I removed the cap, tested it and verified that it was indeed failed. I went to a local Radio Shack and picked up a 1000uf/35v electrolytic, after all, the value is what mainly matters as long as it's not lower voltage than the original. I replaced the new CS21 capacitor back in the circuit (it is polarity sensitive, so pay attention to what the original mounting position is). I reassembled the TV and Viola! Works! No need for the USB cable to the Service Port!
I hope this helps someone!
-Matt
