Televison & Video Logo
Joe V Hall Posted on Feb 15, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Sony KDL - 55W900A.... the TV comes on for about 5 minutes then it goes off the logo is flashing red. Online indicates that could be a power supply issue are the power supply motherboard. I am looking for someone that can answer the questions and tell me the steps to possibly repair
ADMIN Eric
Level 3:
Top Expert:
  • Sony Master 39,345 Answers
  • Posted on Feb 15, 2021
ADMIN Eric
Sony Master
Level 3:
Top Expert:
Answers
39345
Questions
0
Helped
794397
Points
588033
Count the flash sequence and then gargle what you find.
Google "Sony KDL55W900 blink codes".
5 Related Answers
Anonymous
  • 43 Answers
  • Posted on Jan 06, 2008
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Anonymous
  • 9 Answers
  • Posted on May 12, 2008
SOURCE: Sony KV34XBR800 Won't Turn On
Is this your TV's problem? - about a 5 year old KV-34XBR800 suddenly won't power up - yet sometimes will still power up if left alone for a little while. For a possible fix to your Sony KV-34XBR800, go here http://www.avsforum.com/avs-vb/showthread.php?t=928945&page=4
for my post #108 woth a step-by-step solution including pictures. $21.83 is all it cost me and 3 hours is all it took, though I was also taking the time to photograph and document the repair. I fixed my own TV as many others on that forum have. Feel free to contact me at [email protected] if you run into difficulties. Please don't discard that set - It's one of the best sets Sony has made, according to lots of people online.
-Dave
P.S. This fix will also work with some other KV series TV's with the same problem.
Anonymous
  • 10594 Answers
  • Posted on Mar 14, 2009
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Anonymous
  • 10594 Answers
  • Posted on May 18, 2009
SOURCE: SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
Jaime Hernandez
  • 2351 Answers
  • Posted on Jun 08, 2009
SOURCE: Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to [email protected]
2answers
Five red blinks in Sony LED TV KDL 40W900A.
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
When turning on tv. screen will display Bravia image & then go blank. red light flashes SIX times
Power off the television. Wait a few minutes, then power it back on. If this does not correct the issue leave the power on, point your remote control towards the Sony television and hold the down arrow button. While holding the down arrow button press the "Power" button. Release the down arrow button and the Sony TVicon1.png will reset itself to factory settings. Once the television performs a scan on itself your problem should be gone.
Good Luck Ed Pinero
Read more: How to Troubleshoot the Standby Indicator Flashing on a Sony TV ' eHow.com http://www.ehow.com/how_5925008_troubleshoot-indicator-flashing-sony-tv.html#ixzz2KBk1cWbu
1helpful
SONY KDL-40S4100 flashes 5 times
try to force on the tv un plug and use remote when tv iv completly off. and press display 5 vol+ then power and see if tv stays on and in service menu look for eror code .if tv stays on if it cutts off then one of lamp in screen is defective. its mean screen defective
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
3helpful
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
