Question about Ricoh Office Equipment & Supplies
I have a Ricoh SG7100dn I get one error code fixed then it gives me another I have new ink & collector it ate all cyan within 10 min , have no idea why and now its giving me error code 20222
Posted by Nichole Andree on
  • The Spaminator
    The Spaminator Feb 14, 2021
    Hi Nichole Andree, read a few other forums.
    saw mention of a label on top of cartridge that has an air vent . Apparently this has to be open.
    Is air vent on top of cartridge open ?
ray gallant
    Top Expert:
  • Ricoh Master
  • 74,163 Answers
AND HP WANTS THEIR CARTRIDGES AIR TIGHT SO IT CAN NOT LEAK OUT . THATS WHY I CAN NO LONGER REFILL THEM WITHOUT TAPING THE HOLE SHUT
Posted on Apr 23, 2021
5 Related Answers
Anonymous
SOURCE: Ricoh CL2000N Error Code SC230
The manual says this code means " BCU Received no Feedback from LD" I have no idea what that means, but maybe it will help a tech on hear tell you more.
Posted on Jan 24, 2008
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: Epson R260 ink cartridge problem (yes, with the genuine Epson ink)
Try this:
http://er.epson.com:8001/start
Posted on Feb 20, 2008
Anonymous
  • 1447 Answers
SOURCE: Changed the black ink cartridge but can't print just black
Hi-
Sorry to say but NO you can't print if there are other inks which ae empty, thats one safety features of epson printers to prevent nozzle clogging. change the other ink carts as well for you to continue printing.
Posted on Sep 02, 2008
Anonymous
SOURCE: Error 1681 more than one Cyan cartridge installed
I have the same issue as well - I just open the printer, pop out the cyan cartridge, and reinsert it (the same one). This generally works - sometimes I need to do it once or twice. I figure I'll be patient and keep doing this until I a) finish the cyan ink cartridge, b) replace it out of annoyance, or c) through the printer out the window in total frustration.
Interesting to hear about "faulty" cartridges though - I shell out for the "authentic" Canon cartridges which you would think would be reliable - maybe I should switch to using the imitation ones if I'm going to have issues with them anyway...?
Posted on Apr 26, 2009
Anonymous
  • 78 Answers
SOURCE: My ricoh 2022 is giving me error code sc650 on my
Communication timeout error between
SBCU and duplex unit
650 B
The SBCU cannot receive a response
within 1 second from the duplex unit.
• Serial line connecting SBCU and
duplex unit unstable
• External noise
• SBCU board and duplex main board
connection defective or loose
• Duplex main board defective
• SBCU board defective
Posted on Jul 22, 2011
Testimonial: "excellent advice "
2answers
Printer Ricoh sp 210SU "service call error SC491". using compatable cartridge instead of Ricoh original. Service centre suggests to change the cartridge to solve the issue. any idea else pl share me
SC491 on a Ricoh SP 210SU is a code for bias leak.
The machine detects that a bias leak has occured from the drum charge, development charge or transfer charge.
PWM signals are sampled at 20 msec. intervals. This SC is issued if 10 PWM samplings within 200 msec. are abnormal.
• HVPS (high voltage power supply) harness loose, broken, defective
• HVPS board defective
• AIO terminal defective (the terminal for the toner cartridge)
• Cycle the machine off/on
• Check all the harness connections of the HVPS
• Check spring-loaded AIO terminal installation behind the HVPS.
• Replace HVPS.
Usually this error is related to the cartridge. Some manufacturers of compatible cartridges will replace the cartridge with a new one.
At least they should give a discount based on how many pages that was printed before it failed.
I have not seen this problem with a new genuine Ricoh cartridge.
It is important that the cartridge is not refilled more then 3 times. There is no counter on this, and companies that refill cartridges they collect (with unknown number of cartridges) may have problems quite often.
I have a SC20222 error code on my ricoh sg3110dn printer, any ideas how it can be fixed - can't find any solutions on line can anyone help me....PLEASE
This question has been asked before on fixya (in 2013). One answer suggested that you need to "change the ink collector unit"?
2answers
I have an error code, Service call - SC396. Please lelp me fix this!
Drum Motor Lock Error.
need to check drum unit gears and main moter is ok
My ricoh 305on is displaying error 990. I have
change the ink collector located in the rear of the machine
2helpful
2answers
I have a Ricoh G7500 printer that is giving me an ERR-990 when I turn it on. I don't see any documentation on Ricoh error codes.
990 A Waste Tank Full Sensor Defective
The waste ink tank full sensor (a
photosensor) on the corner of
the waste tank is not operating.
• Waste ink tank sensor on the corner of
the ink waste tank is defective.
• Replace the waste ink tank.
9helpful
2answers
Hello, we're getting an error code of 990 on a GX5050n inkjet printer. The printer is fairly new with only a dozen or so printouts. Thanks.
make sure printer is off. Then old down escape and online button at the same time. Continue to hold these two buttons down then turn on printer. Continue to hold those two buttons down (will take about 2 - 3 minutes). This should clear that message - worked for me!!!
2helpful
4answers
E-02 Error "Replace Ink Cartridge"
There is a program called SSC Service Utility, but for me it didnt work, I still have the same problem. But, who knows for you work!
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
Timothy Van Der...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
