How do you change language?
This worked for me:
Power the device off. Press the power button and +volume simultaneously, hold for 5-10 seconds. The reboot directory will appear. Use the +volume to move to Recovery boot, use the -volume to select this option. An android will show and the screen says "no data". Press the power button and +volume simultaneously and hold 5-10 seconds. Several options will appear. Use the volume buttons to scroll to the wipe data option, use the power button to select this option. The device will reset to factory default. Any personal data/apps will be erased from the device.
The following manual's troubleshooting section refers to a recovery from safe mode on page 16 by repeatedly pressing a button. Sadyly, if this does not work, you might want to consider your warranty.
http://legacy.curtisint.com/html/CustService/Manuals/INSTRUCTION%20MANUAL%20FOR%20SLTDVD1024.pdf
Alternatively:
If you can navigate the screens you can, tap settings,default set, yes.
