Question about PfaFF Sewing Machines
Model 6110. Dropdown foot is not fully descending. How can I repair?
The little lever lifts foot ok but when I try to drop it down on fabric it goes so far then slows right down. If I leave it down when I put the machine away, it is tight enough when I go back to it. Someone in an older query was told that the lubricant had become thick and they had opened the machine to clean and lubricate. This fixed the problem but I cannot see any way to open the machine to access this foot lever. Help?
Posted by blacks117 on
Jimmie Sill
  • PfaFF Master
  • 706 Answers
The grease that is their may be thick. Get your hair dryer out and warm the total parts that rises and falls when you move your lever.
Continue to move the lever while you're heating the parts. You should notice a big change. Try to clean off any old grease. After you do this use some good synthetic oil on the moving parts.
Posted on Feb 15, 2021
Testimonial: "Brilliant idea. I looked in my tools and found a screwdriver bit, not a Phillips but one with more “teeth”. Got some in a set from Lidl at one time. I lifted the handle, opened the top flap where the spool would go and removed two screws, one at either end and popped the top section out giving access to innards. Then as per instructions I let the hair drier heat things up, lifting and lowering the foot at the same time. Gradually the foot began going further down until it was landing with a clunk. Mission accomplished! I finished off with a few drops of oil from the cat hair trimmer and put the panel back on. The job’s a good ‘in as they say. I can’t thank Jimmie enough ??"
5 Related Answers
Anonymous
  • 41 Answers
SOURCE: Pfaff triptronic 2040 sewing machine
Could be a couple of things:
  1. Foot control is bad - take foot control to your local Pfaff dealer to try on one of their machines. If their machine won't run either, it's the foot control and you can look into repair/replacement.
  2. Machine has a short or some type or computer board problem - take machine to local Pfaff dealer and try with one of their known working foot controls. If the machine still doesn't work, your dealer will need to diagnose what is wrong.
Hope this helps.
Happy stitching,
Kim & Linnette
www.sewingexpressions.com
Posted on Dec 03, 2008
Anonymous
  • 13 Answers
SOURCE: Manual Sewing machine Pfaff 1229
http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
Posted on May 27, 2009
Anonymous
SOURCE: Have a model 6091 Pfaff. The sewing foot will not lower complete
I had this same problem. On the bottom of the head there is a slide switch. Lay your machine on its back and you can easily see it. Slide it back and your problem should be solved.
Posted on Dec 04, 2010
SOURCE: how do you adjust timing on pfaff 138 sewing machine
Take the foot off the machine
Remove the needle plate
Remove the feed dogs
rotate by hand until the needle is at the lowest position
continue rotating until the needle rises 2 mm
the hook assembly should be passing exactly by the scarf of the needle
if not loosen the two screws that secure the the hook assembly and rotate the hook assembly by hand until it is exactly at the scarf of the needle and the distance between the hook and the scarf is .1 mm (almost touching the needle)
tightened the two screws, replace the feed dogs and foot and it should sew perfectly
Posted on Sep 22, 2012
aeroseek
Michael Williams
  • 55 Answers
SOURCE: foot pedal dead, machine keeps sewing!
Sounds like your foot control is faulty.
I can supply foot controls for 99% of sewing machines.
Mike
[email protected]
http://www.sewingmachineswales.com
Posted on Oct 10, 2012
1helpful
Elna tsp presser foot does not move when the lever is moved up or down. I suspect it's unhooked inside. Is there a way for me to get inside to check it?
there is a spring on the presser foot applying pressure when you release the lever, so that there is constant downward pressure onto the fabric from the foot as you stitch. If there seems to be no pressure on the presser foot, then this spring may have broken. If this is a Star series TSP with a beige top and white body, then you undo screws on the top panel to gain access. There is also a TSP in the Air Electronic later model range, there is also two screws on top but you need to work around the carry handle to actually lift and move the top panel to the back of the machine. I'd suggest this could be a job for the SM repair mechanic.
2answers
I need to raise the foot to take extra thick fabric, how do i do this?
I know that Janome machines have an extra lift just by lifting the foot lever up higher but if it is not part of the machine, I don't think you can do that.
2answers
How to fix sewing reverse
try to pull the fabric as you hold the reverse lever.....pull away from front towards yourself. the dogs pull the fabric in the opposite direction. make sure your stitch length is narrow or "1" ...reverse only works with a straight stitch foot not a zigzag. Sometimes a machine needs a little help getting the reverse mechanism going......
4answers
When I put the presser foot down and begin to stitch, the needle just keeps sewing in the same place, and the presser foot won't allow me to easily move the fabric.
You might want to see if the drop feed control is down. There's a switch (for my Singer machine, you have to take off the removable sewing table/storage, and the switch is behind the machine)...if the drop feed is down, you can't see the "teeth" as I call them which grips the fabric.
Another idea is to back stitch (reverse sewing lever) a couple stitches and then try sewing.
Make sure the foot speed control is hooked up correctly. https://wiki.artisansasylum.com/images/0/0f/Sewing_Machine_--_Singer_3116_--_Manual.pdf This is the manual for your sewing machine model you posted. Good luck.
1helpful
I have a pfaff hobbylock 796.
Has any little kids been around lately? Have they had access to your sewing area and machine? (thinking perhaps the pressure foot tension has been tightened down) If it has been tightened, losen it a couple turns, see if that helps (remember, left to loosen, right to tighten)
When is the last time you oiled this machine? Typically sergers require a clean and oil each time you go to use them. Locate the bar that correlates to the presser foot add a drop of oil to the bar and let it seep in. After a few minutes try lifting the presser foot.
Also does the presser foot lever move at all?
Presser foot on bernina 180 won't go all the way down
Could be a number of things ... does the foot-lift lever go all the way down when you lower the foot and is it unusually 'floppy' when you lower it. There is a small spring inside that should keep tension on the lever and these can ping off if you inadvertently let the foot drop under its own pressure instead of letting it down slowly onto the fabric (they're a nightmare to put back, too !) ... if it has come off, it may be jammed in the foot lifter mechanism. It's also possible that the foot lifter has shifted on the foot bar, in which case it really needs to be looked-at by a qualified Bernina service agent. When raised, there should be a gap of 7.5mm between the bottom of the foot and the top of the stitch plate - if much more than this, it indicates that the adjuster has shifted and you'll need to get it looked-at professionally.
How do I change the presser foot on an elna mini sewing machine?
I dodn't know your model really well but it will be one of the following:
a clip on foot that you just pull down on to remove,
a clip on foot with a button at the back of the pressure foot holder - press the button to release the foot
a clip on foot with a little lever at the back of the pressure foot holder - lift the lever to release the foot
If it is a clip on foot, then you just need to raise the pressure foot lever, put your fingers onto the pressure foot and press downwards, it should unclip.
To put one on, place the pressure foot onto the needle plate under the pressure foot bar and lower the pressure foot bar down onto the foot, lining up the base of the foot holder with the little bar on the foot, it should click into place.
1helpful
Hi, the presser foot is stuck in the down position. The presser foot lever has no effect at all. As I have a project underway, I'm having to lift the foot by hand while I get the fabric under the foot but...
You need to get access to the pressure foot bar area. Open the side cover if you can and look to see where the pressure foot lifter lever meets the pressure foot bar lifting block. Maybe the block has sliped upward. You'll need to loosen the screw, slide the block down a bit, tighten the screw, and check to see if this works. (Not knowing what machine you have)
Thread puckers and has loops , the threader clicks when it goes up and down..I thionk I bent the top threader?
Threader that goes up and down? Is this the uptake lever? I don't know how this could happen unless the machine was dropped.
Lift the presser foot and re-thread the machine to see if the stitching improves.
Always thread a sewing machine with the presser foot up.
13helpful
2answers
Presser foot lever does not lift presser foot
If you can remove the cover on the left side you will see the presser foot bar. On the bar there will be a screw that may be loose. Turn the handwheel until the needle is all the way down and lift the foot manually until just before it makes contact with the needle clamp and tighten the screw on the presser foot bar.
That should do it.
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
Richard Schabler
Ekse
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
