Canon ES900 Camcorder Logo
Question about Canon ES900 Camcorder
Canon ES900 Everything on the camera is operational except that when you attempt to put a tape in, the tape carrier won't go down. Without a tape, the carrier will go down.
Posted by Robert Barr on
ENFORCER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 38,673 Answers
Make sure the tape is not write protected. ray tape is forever and if you need proof what do you think the cloud runs off of?? tape...been in the tape business for 40 years audio, video, data and floppy disks and now linear tape..
Posted on Apr 22, 2021
ray gallant
    Top Expert:
  • Canon Master
  • 74,163 Answers
TAPE UNITS ARE OBSOLETE BIN IT AND GET A NEW DIGITAL UNIT
1 Related Answer
Anonymous
  • 154 Answers
SOURCE: canon es900 8mm camcorder won't allow tape insertion
Canon ES series camcorder was designed with 1000 hour capacitors on the processor boards. When the time comes these capaictors loose value and create problems for the main computer to communicate with other mechanical system in the camcorder. We were able to service well 7 years ago but the life of these component has aged too much to make it good anymore. I wish I have a better news for you but the success repair on 'ES model is very slim and if repaired, the labor charge may run many times over of the value of this camcorder. You can probably obtain a newer used camcorder at decent price and get all you tapes into DVD quick. Good luck -James
Posted on Mar 27, 2009
Can you use hi 8 tape in the ES900 Analog Camcorder
I believe this camcorder is 8mm only, so you won't be able to use a Hi8 tape with it. They will not play right in your camcorder.
3helpful
I have a Canon Elura 65 mini DV camcorder. When I
I had this problem and I only ejected a cassette. I tried new and old cassettes. Same result as you experienced.
What I did and I again don't condone striking electronics as a means to repair them but, at the advice of another post and having tried everything I could think of, I stuck the bottom of the camcorder with the palm of my hand several times and it worked. I don't know why it worked and it really shouldn't have but it did.
I think the real problem is a cleaning/lubrication and ultimately should see service by a local trusted shop. Try it I had nothing to lose and it worked for me.....
4helpful
Canon es900 8mm camcorder won't allow tape insertion
1helpful
Convert my canon es900 video to dvd
If you have a video card that has a video in port, plug in your 8mm camcorder and capture the movie. Depending on the quality you save it as determines the size of the file.
This is the simplest way in leiu of paying to have it done or "projecting" the image onto another media physically.
There are machines designed to do this of course but they're not cheap. If you know someone with a Digital8 camcorder. Sony D8 backward support V8 and Hi8, so you can just simply insert the V8/Hi8 tapes into the D8 camcorder, then transer them to computer in DV format through firewire cable.
Let me know if this helped
4helpful
Canon zr 300 won't take tape inside
FONZIE FIX! It worked for me.
close the tape load door and with your fist, wack it. worked first time for me. the instructions were to wack it harder each time until it closes with the tape. Look up FONZIE FIX.
1helpful
When I attempt to put tape in, it will not let me
HI, I HAD A SIMILAR PROBLEM AND HAD TO SEND THE CAMCORDER TO THE REPAIR CENTER IN N.J. COST WAS 69.00 BUT WORTH IT, K BERATIS
1helpful
2answers
Tape won't insert
take off battery, set date and time, bang on non carrier side 3 or four times w/ screen closed, voila! worked for me too!
5helpful
Eject
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To manually remove the tape from the Canon ES900 video camera do the following after reading all below.
1. Remove the two small screws from the tape door face. I show the entire carriage removed.
2. Look for the small metal peg on the left side, about 1” down from the top of the tape carriage.
3. Using something small push down on the peg to release the tape door.
4. Important Note: Most likely the tape will still be wrapped around the video head and held there by two capstans, (one on each side of the head)
5. Carefully pull out the tape not damage it any more than necessary. Keep in mind this might cause the player to “eat” the tape at this area so smooth the tape here with your fingers (nothing metal) and wind the tape to begin playing past this area if possible.
It seems this is a common problem with this unit; Canon should have put a better motor here in this critical area.
Good luck, hope this helps everyone,
1helpful
Self-eject
Hi there, I think I can offer some info, though it's not good news.
This cassette ejection is controled by a small motor in the bottom of the cassette carriage (see picture). Unfortunatly whether the problem be this cheap little motor or a switch that controls it, taking it to a repair shop would cost much more than this little camcorder is worth.8477600.jpg Sorry for the bad news, I have the same camera as you can see it's taken apart now. I posted another solution to get the tape out if you come to that problem.
Hope this helps
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
