SOURCE: FLASHING EXCLAMATION POINT
Link to the manual: http://h10032.www1.hp.com/ctg/Manual/bpd09762.pdf
Basically it only means that the printer needs attention.
I would check for a paper jam or misfeed, out of paper, low or empty toner.
SOURCE: Orange circle with a flashing exclamation point.
this usually indicates a gearbox fault. take it to a garage and they will plug a laptop into the vehicle and tell you what exactly the fault is.
hope this helps.
SOURCE: what does the warning light - yellow circle
Are refer to the Brake System; in RED and YELLOW condition, continue driving cautiously:
More details about this Warning Lights you can find in the 2003 Mini Cooper - Owners Manual (page 16 and next).
I really hope helps with this (remember rated this help) Good luck.
SOURCE: My fully charged Roomba 560 just moves a few
You have dead nimh (nickle metal hydride) batteries
You
will need a replacement. You can test for this by removing the battery
and holding the power button for 15 seconds. This will restart the
charging cycle as if the battery were new.
SOURCE: Light that looks like exclamation point in a
First off you need an owner's manual. You can get a free one here. http://pdfservicemanual.com/automotive/2001-ford-taurus-owners-manual The light that looks like a gear with an exclamation point inside indicates there is a problem with the transmission. May just be low of transmission fluid. To check the level dive the car until the transmission is warm, park on a level surface, place gear shift in park with engine running, and check transmission fluid level. Add only if necessary and do not overfill. If it is not low of fluid then seek professional help. The exclamation point in a circle under the fuel gauge next to the Brake light indicates you are low of brake fluid. Check the level of the brake fluid. If it is low you more than likely need to check your brake pads as they are worn out.
