Televison & Video Logo
Sweta Joshi Posted on Feb 09, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Samsung 65” QLED TV, purchased just 1 year ago. I am not sure this happened due to thermal crack or my son just hit the screen with some toy. I don’t see any single external crack on the TV. I just purchased this 1 year ago. Is there any way to resolve the issue? Thank you in advance doe your answers. Sweta
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Feb 09, 2021
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14987268
Points
237762
The screen says there is no signal. The fault should be either with signal cable of the signal device, Just tune in the TV to a local station, If you can see a picture there, there is no fault to the TV, Check the connections.
5 Related Answers
vinhson65
  • 257 Answers
  • Posted on Aug 14, 2009
SOURCE: White dots in the screen of my Samsung DLP HLT-5075S
This problem cause by DMD chip has been defective. This chip consist of over 2 mil mirrors tiltling to make picture. Some of the mirror does not function causing white dots. If you are in Cali, Orange, Sandiego or near by. Email me at: [email protected] so I can come and help you. This replacement need skilled technician to relace as it was inside the DMD board.
bilcast
  • 48 Answers
  • Posted on Dec 23, 2009
SOURCE: i have a sony bravia 40 inch and my 2 year old son
Generally, no. I know some one who had a wii remote hit their screen and it cost more to fix than to replace
Jeancarlo arias
  • 40 Answers
  • Posted on Jul 08, 2011
SOURCE: is it worth fixing a
Depending on the extent of the damage, you may not be able to repair you broken or cracked plasma TV screen. Plasma TV screens consist of a special mixture of gasses (plasma) sandwiched between two pieces of glass. If the screen has cracked or broken to the point where the gas can escape from between the glass then the screen cannot be repaired. You will be better off purchasing a new set
lkjhbewrgwe
Michael
  • Posted on Dec 01, 2014
SOURCE: CRACK LCD TV SCREEN
Take a look on amazon. here Amazon com lcd tv replacement screens. I hope I have Helped. Cheers
adjsn222
Chen Pei
  • 109 Answers
  • Posted on Sep 14, 2016
SOURCE: Please advise if you would be able to guide me as to where i could purchase tv parts...
This site can provide high-quality, highly cost-effective Samsung parts and recommend it to everyone to see!Samsung
I have a Samsung QLED Q60R Television. How can I change where my local news and weather come out of?
Question edited for clarity, spelling and remove abbreviations.
Question moved from Motorcycles category.
It has a feature called 'Ambient Mode'. You would better off having the Weather Network App on the television and on your Smart Phone and set it for Notifications. The App is free.
The TV app is available for download on Roku, Apple TV, FireTV Stick, Amazon FireTV, AndroidTV, Panasonic, Sharp, Sony, Samsung, Philips, LG, Huawei, and through most other Smart TV and Streaming devices.
The Weather Network, M?t?oM?dia TV Apps - FAQ
Use Ambient Mode on your Samsung TV
Samsung https://www.samsung.com > answer > ANS00082422
You can display d?cor, weather info, news, photos, and artwork. You can even ... Press the Down directional button to change these settings: Color and Theme ...
Samsung https://www.samsung.com > answer > ANS00088842
With Ambient Mode, you can display a variety of content on your TV screen, including images, artwork, weather updates, news headlines, and even music. To use ...
It is a nice set!
https://www.samsung.com/us/televisions-home-theater/tvs/qled-4k-tvs/65-class-q60-qled-smart-4k-uhd-tv-2019-qn65q60rafxza/
Samsung Qled tv has dark bands should replacing the led strips fix this problem?
It may but there are a lot of other things that could cause this from a board issue to connectors not making good contact
2answers
Samsung 55" Q80A 2021 has green tone/tint on whole screen.
The screen being green on your TV is either caused by a loose or damaged cable connection of a media component to or from the TV or it could be that the TV's T con board is having problems and it would be more cheaper to bu a new TV than to try and fix the one that you have is broken.
My son hit the tv with a ball and now there's no
did the ball hit the screen and is there any cracks on the screen or the screen broke? what had happened.you can get the power back,it needs some repair
1helpful
My son pressed some option on tv, made the screen zoomed in . It's kind of wavy and the people on picture are really stretched.
hit your TV lightly on left side or right side or on top & then observe ..........you will get normal picture or it comes & again it goes....if it is happening like that then following is the situation..........after 4 or 5 yrs in some TVs on main board at some soldering joints crack develops....then due to loose contact picture becomes small in size or disappears ...........when we hit that lightly then those loose contacts joins temporarly & again picture appears for some time............so solution is ......TV main board should be observed carefully & most of the joints should be re-soldered.......only a good service engineer can do that........even after hitting TV lightly if there is no response then main board has to be checked completely........in your case iam sure it is loose connection problem.........joints should be re - soldered ...100% it works again (2inch on top will also gets solved )................this problem cannot be solved by user unless user has idea about components( resisitors, transisitors, diodes,...etc) , have soldering iron , multimeter & other tools....................so contact good TV service engineer -------- IAM SURE PROBLEM IS NOT BECAUSE OF YOUR SON BUT DUE TO ITS AGE
4helpful
3answers
CRACK LCD TV SCREEN
I had one broken a few months ago. I got a couple quotes.. it was about $200 less then a brand new one. I'd just buy a new one.
For the new TV I'd pickup a screen protector for it. My son threw a toy at my TV the other day and I nearly had a heart attack from the flashbacks. Thank God I picked up one of these a few weeks earlier. It stopped it. LCD screens really break easily as you know. http://www.tv-armor.com
Mike
54helpful
9answers
CRACK LCD TV SCREEN
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
