SOURCE: WD63 Drain during wash but not dry cycle
the chances are you water valve has gone the drying cycle requires water to convert steam back to water, or poss your condenser is blocked this cant be cleaned easily better to change I dont know how competent you are if you have a muti meter you could test the soleniod which should have a resistence of around 3800 ohms. the valve is a triple one and the one that serves the condenser is the one facing downwards, disconnect power,take back off, turn water suppy off,take the 2 leads off the bottom solaniod only ,put your meter on contacts make sure you have selected crrect range on meter ie:10mohms if 0000 solanid faulty.Change valve if reading says 3800 valve ok change condenser
SOURCE: The washing machine makes a
When
my washer did that, I found that the shocks that hold the tub were
bad...
Check out this tip I wrote about the noise and
vibration that front load washers can make..
Washer Problems
Washer
noise
when spinning
heatman101
If a machine is out of balance when spinning it will shut down---there's an unbalance switch that controls this---also on some machines if not properly set level or feet not touching the floor causing the machine to rock---it will shut down---the remedy for that is to redistribute the clothes then is should resume spinning----another issue could be the timer----out of sequence or jumping ahead during that cycle---has the timer/control ever been wet as this will cause some issues---this is my thoughts on this--good luck
Hi Nelson Isimel, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
have you checked the lint filter is not full ?
