SOURCE: Kenmore frig will not cool
if compressor is hot that means comp- is trying to start but the relay /overload is bad allow comp to cool down unplug from wall and replace with exact type 1/2hp 1/4hp 1/3hp etc make sure all wireing is correct and unplug before starting that model may or may not have a run or start capacitor replace it also..
SOURCE: Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
SOURCE: freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
SOURCE: fridge not cooling
hi,
Issue seems with the relay switch of the compressor .Please get it checked by an expert.
SOURCE: freezer defrosted completely. fridge is barely
The compressor relay is bad on the main control board . Unplug the refrig and pull the refrig out and remove the 8X10 small panel on the back . You will see a blue plug with 3 larger (120v) wires going to it . Remove this plug . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . (this is on the plug NOT the board ) . Using a short piece of insulated wire , with about 1/4" stripped off both ends , insert 1 end into wire1 and the other into wire3 . Plug the refrig back in . This will start the compressor to verify the main control board is bad . Pt # WR55X10942 .
