Question about Freezers
Have igloo freezer and orange power light and green run light .the green light is not lit.
Posted by Esther Ganoe on
Tom Chichester
    Top Expert:
  • 61,667 Answers
The green light may have failed without affecting operation.
Posted on Feb 06, 2021
3 Related Answers
Anonymous
  • 7 Answers
SOURCE: Defrost light stays on
Try advancing the defrost timer manually.
Posted on Jan 17, 2008
luisa_sgro
  • 713 Answers
SOURCE: Machine stops and the following lights (in UPPER
Hi just read your posting.Now when the machine stops and beeps a series of lights will light up.They will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine stops and beeps,Is it the 1st and 4th or the 3rd and 6th ---etc---?Also please supply the model number of your machine which is on a sticker on the back of your machine, top left.Looking forward to your reply.
Posted on Sep 26, 2010
mike cooper
  • 884 Answers
SOURCE: Igloo chest freezer 7.2 cubic ft seems running all the time?
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
Posted on Apr 30, 2014
I have an igloo frf1050 10.6 cu ft chest freezer. power (red) and running (green) lights are on. compressor hums for 6 to 8 sec. then shuts off. no cooling or freezing. any help?
Compressor may be bad. Also could be the relay that plugs into side of compressor that’s bad. Inexpensive, easy to replace part if it’s the relay.
Sep 21, 2018 | Freezers
Why do both green light and orange light stay on all the time?
Without knowing much about Frigidaire , I would say at a guess that the green light would mean there is power on and the orange would be that the temperature isn't down to what you have selected yet. Most freezers have these 2 lights or a display showing the same. Check that the freezer hasn't frosted up and the food has frozen correctly. If you have a thermometer, most domestic freezers should run at around -18 degrees celcius. If its a larger type for long term storage, the freezer would normally run at around -20.
Apr 11, 2016 | Frigidaire Freezers
Re lights lit on freezer
Red light lit on freezer means that is not reaches operating temperature.
Most often the old freezer has three indicator lights.
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees
- orange light : pressing the so-called SUPER-switch which means that the compressor is running continuously. The SUPER-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
In new freezer managed by the electronics, this function has a predetermined maximum duration, in order to protect the compressor, and can have different marketing names like "shopping".....
Dado
Sep 02, 2014 | Electrolux Freezers
Apr 30, 2014 | Igloo Cooler Igloo - 5.2 Cu. Ft. Chest...
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
Orange light is on instead of green light on freezer what does this mean
- Green light : that it is brought to a power source and turned on - Red light : means that the temperature is above -18 degrees - orange light : pressing the so-called S-switch which means that the compressor is running continuously. The S-button switch on a few hours before you begin deep-freeze foods. Freezing time depending on foods quantity (kg). With old freezer must be careful to turn off the switch S (orange light) when the red light goes out or when foods are frozen, otherwise after a few days may burn out the compressor. You should be following the instructions from user manual.
Dado
Jan 14, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Got three lights on my whirlpool super chest freezer green red and orange. Orange one you can push in and this illuminates it. what is itn for?
This is a super freeze button, it is for when you get a lot of frozen food and put it in you can push the super freeze button and it bypasses the thermostat and runs the freezer constant to freeze the food quicker.
Apr 18, 2011 | Whirlpool Freezers
Philips Freezer
I used to sell freezers.the green light tells you the mains is on and the freezer should work.The red light is to inform you the freezer is not low enough temperature,and the orange light is a fast freeze light to over ride the thermostat for use when introducing fresh food.It should not be used for prolonged periods as it may burn out the compressor although in your case you already have a problem and should seek advice or buy another freezer.If you get a cheap freezer thermometer it should confirm what I am saying.
Jun 24, 2008 | Freezers
Freezers Logo
Top Freezers Experts
Dennis Boxerman
Muntejaya Ginting
Muntejaya Ginting
Dan Webster
Dan Webster
Are you a Freezer Expert? Answer questions, earn points and help others
