Question about Tablets & eReaders
How do you charge a jp5 tablet, and what does the charger look like?
Posted by John Thomas on
Valentino Ward
  • 3 Answers
Hard rest a jp5 tabet
Posted on Nov 18, 2021
ADMIN Canada
    Top Expert:
  • Tablets & eR... Master
  • 41,541 Answers
Standard Samsung Mini D plug
Charging Cable for Jpay Galaxy JP5 Mini - Samsung Galaxy ...
androidforums.com > ... > Samsung Galaxy Core Mini
That Galaxy JP5 Mini will most likely have a microUSB port, so you might ... https://www.androidauthority.com/this-is-the-tablet-made-for- ... Aug 20, 2019 · 4 posts · ‎3 authors
jp5 tablet heat issue - Android Help ' Android Forums
Jul. 31, 2019
Jp5 mini can anyone answer me? - Android Devices ...
Jul. 18, 2020
can tablet working without battery? - Android Help ...
Oct. 9, 2016
Jp5 tablet - Android Lounge ' Android Forums
Jan. 26, 2020
More results from androidforums.com
JP5 Tablets - JPay
offers.jpay.com > jp5-tablets
Availability of the JP5 tablets varies depending on the state, facility and other ... Includes accessories like earbuds, screen protector and batteries or charger ...
Posted on Feb 06, 2021
Jp5 tablet won't process to fully workable screen. Tablet just shows jpay sign
It could mean that your tablet might be broken then or the screen is no working anymore and needs to be repaired.
2answers
Factory reset jp5
Go to setting go to security click on that and scroll down to factory reset this if u can access your tablet if not u will after hard reset the tablet if u can't access the tablet
22helpful
How to unlock jp5
the address to send your jp5 is Media Department 3220 Keller Springs Suite 118 Carrollton Tx.75006 or by calling 954-862-6900 ext6012
1helpful
2answers
My tablet was in use, needed charging, it shut off. Now it won't charge or come on
It sounds like there's a problem with the charger. The wire on the charger is rather delicate. So is the port on your tablet where the wire plugs in. There may be a break inside the wire. If you dropped your tablet while the wire was plugged in and it hit the floor on the charger plug, the charger plug could have damaged the charging port in the tablet or the wire itself could be damaged.
Find someone else who has the same tablet and ask to switch chargers to see if either of them still work on the other tablet. If your friend's charger starts charging your tablet without a problem, then the problem is a a broken wire in your charger. If neither charger will charge your tablet but both chargers charge your friends tablet without a problem, then the problem is with the charging port on your tablet.
Digiland tablet won't charge. Is there a way to
Depends upon exactly what's happening.
  • When you plug in your charger, does it try to charge the Tablet? ie Does the Charging icon come on the screen briefly when the charger is plugged in with the Tablet turned off, or does the little charging 'lightning' symbol come onto the battery icon on the home screen when the Tablet is running?
  • I assume the battery has gone flat, but will the Tablet turn on when the charger is connected?
If the charging icon comes on, and/or the tablet will run on the charger, then both the charger and the charge port connection on the Tablet are OK, and the most probable cause of failure is the internal battery which will need to be replaced.
However, If neither the icon comes on nor the Tablet runs on the charger, then either the charger has died, or the plug/socket on the Tablet where it connects is faulty. The most likely cause is that the charger has died and will neeed to be replaced
There is a slight chance that the internal charging circuits in the Tablet may have developed a fault, but that is highly unlikely {:o)
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Tablets & eReaders Logo
Top Tablets & eReaders Experts
ADMIN Canada
ADMIN Canada
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
