Ebay lamps can cause this as they are not originals also the balast supply, is gas discharge type, can fail.
Posted on Feb 05, 2021
SOURCE: Intermittent lamp turn off
your lamp is fried just change it i did the same to mine and it works just like a charm
Posted on May 28, 2008
SOURCE: Sony Grand Wega KF50WE610 Video/Audio disappears every 1-2mins
Hello apharcha,
99.99% its the lamp. You may also have a faulty door, but thats kinda just 2% possibility. Change the lamp...its due anyway.
List Price $200.00
Part Number
A-1606-034-B
Description
LAMP BLOCK XL2100U
Best regards
circuitcity
Posted on Jun 21, 2008
SOURCE: The LCD light (green) flashes for like 6 times and then the pictu
Sounds like a bad lamp, the lamp needs to be replaced every few years and rebooting is a symptom of a bad lamp. you can buy a lamp for around $100 -120 if you search the internet
gd lk
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Aug 19, 2009
SOURCE: I have a sony wega kdf-e50a10 I replaced the lamp
Without having a technician there to diagnose this problem is going to take some troubleshooting. First, I would take the lamp back out of the TV and then reinstall it and try turning the TV on again. If that does not work there could be numerous things wrong with the TV. The heat sensor in the TV could be bad or the actual light engine, which is essentially the heart of the TV, could be bad. If it is the light engine then it is cheaper to buy a new TV.
Posted on Feb 28, 2011
SOURCE: just replaced lamp/housing and now
Strange situation, have you tried unplugging it for a few minutes and letting the TV cool. I have a older 2006 Sony SXRD rear projection and it takes forever to turn back on if you shut it off then turn it back on. Check this link and maybe its giving you a blinking code. Try counting the number of blinks. Hope this helps.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Posted on Jun 17, 2011
