Question about Brother Sewing Machines
I just purchased a Brother Galaxie 131 for $15! It's in great shape, mint almost but doesn't want to run. Im very handy and know that the problem is in the cord or light/motor block. I don't really want to break the board backing on the block to open it up. Does anyone know a way inside with minimal damage? I can see that the wire's insulation is cut on both sides of it so I hope when I open it up I can see any other issues. I could also use a manual if anyone knows where to find one.
Posted by Jessika Dearing on
  • Jessika Dearing
    Jessika Dearing Oct 05, 2021
    I fought with those boogers for ever but finally got them out. The do kinda screw in but its also like a rivet so it was weird. Whe i got the box open the wire was cut from ... i guess the sharp edges of it. I guess I'm not really sure how but both wires were cut where the enter the box and the switch had barely cut into the wire. So i got all that fixed up but the rivets were trashed and the Access panel now had to much clearance so doing my normal thing I panicked!! Lol, no I just got a paint stirring stick and cut it to size and vaw-la! A great machine for $15!!!
    thanks for the help!! I wasn't sure where to start.
CJ Rock
  • Brother Master
  • 3,671 Answers
Suggest using a drill bit approximately 1/2 the diameter of the fastener head and drill out the head. Take care to start near the center of the head.
You might try a pair of vicegrips to get a hold of the head and gently twist counter clockwise to see if they might screw out, but likely they are a simple barb and will twist but not unscrew.
Posted on Feb 04, 2021
5 Related Answers
GM Elec
Bruce Bracey
  • 1000 Answers
SOURCE: Rear Windscreen wiper not working Seat Ibiza 2003
smonahan, The rear wiper fuse is actually a circuit breaker. It will reset itself.
Your wiper arm has probably stripped were it attaches to the motor shaft. You can check by trying to move the wiper arm with your hand, if it moves back and forth, its stripped. A new wiper arm will be needed.
Try it and let me know.
Regards,
Posted on Feb 12, 2009
Anonymous
  • 41 Answers
SOURCE: I just purchased a 2000 VW Beetle 1.8 Turbo but,
If the light goes out after engine gets alittle warm, this is normal. Since there is no temp guage, VW uses this light to inform that the engine is cold. When that same light flashes red, it means that the coolant is low or the engine is overheating.
Posted on Mar 03, 2009
Anonymous
SOURCE: Dismount door panel. VW Polo Net
Sounds like it is a broken window regulator. You will need to remove the door panel to fix it. Mine broke and I can actually pull the window up and it will stay until the vibrations of the freeway eventually make it slide back down again (this would be a temporary fix of course). Anyways, there are a couple screws behind the door handle I believe, and then some snaps around the edges, and some clips along the window line. You should get a Bentley's manual so you know exactly how to fix the window regular.
Posted on Jun 17, 2009
Anonymous
SOURCE: 2008 Chevy Silverado 5.3 Motor Knocking Sound
Its is a common problem for these engines. There is a problem with the design of the piston where carbon causes a knocking sound, very noticeable when its colder and has been sitting. It should go away after it warms up. If it does not, then it is probably something else all together.
The only way to fix the problem if it is only knocking when its cold is to pull of the heads and soak the cylinders and piston heads in solvent.
I have a 2001 Silverado 5.3 that has been doing it since I got it, I contacted GM about it and they assured me it does NOT do any damage to the engine.
Posted on Oct 09, 2009
Anonymous
  • 10 Answers
SOURCE: VW POLO 2004 FRONT WIPERS NOT WORKING
look in your owners manual
Posted on Jan 24, 2010
1helpful
How to change Brother compal galaxie 870 sewing machine needle default that starts on the left to default to the middle
Some machines have the left setting as the default. Those machines have the bobbin case that is installed from the left side of the machine. For most purposes, this default cannot be changed to center. Machines that have the bobbin case installed from the front of the machine generally have the needle center default position. However, it appears to be a newer model machine (post 1970), so there is a good chance your machine has a needle position setting.
Brother Compal Galaxie 870 Service Manual free download schematics...
Brother Sewing Machine Manuals Instruction and Repair Manuals
1helpful
2answers
Looking to buy a embroidery unit to fit my brother super galaxie 3100d or one the will fit please help thanks lyn
Contact the manufacturer. Or you can search online:
Make + Model + the word "embroidery"
You may even find something on eBay or Craigslist.
3answers
Does anyone have a Brother Super Galaxie 3000 needle plate they no longer require or would like to sell. Part Number is XA9844 which is written under the needle plate.
Search for the part on the internet. There are sewing machine parts vendors or sometimes the part will be available on auction sites, ie eBay. You can also look for internet groups who sell sewing machines, parts, accessories, etc.
Do you have insstructions for Brother Galaxie 8020.
Search the internet for:
Manufacturer + Model + the word "Manual"
or search YouTube videos for your machine. You may not find your exact machine but instead a very close model that will help you. Machine models tend to be threaded and operate in the same manner.
youtube Brother Galaxie Google Search
3helpful
2answers
How do I fix the LCD screen of my Brother Super Galaxie sewing machine the screen does not light up
the machine needs to be taken to a sewing machine repair shop, to see if the computer needs fixing
2answers
1helpful
Brother sewing machine - Galaxie 8015, running rough and loud.
Oil every moving part. Clean out all the lint (Air cans are wonderful for this) and change the needle, If that fails...get a tune up from a professional.
Sewing Machines Logo
Top Brother Sewing Machines Experts
Richard
Richard
Level 1 Expert
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
