Question about Food Processors
Hobart fp350. What is causing unusual noise during operation?
Not sure if it's a grinding/clicking noise like a gear or an electrical switch buzzing noise.
Posted by Tiger Anthony on
The rubber gear attachments with the grinding glass jar is somewhat burned because if i put the vegetable to grind it wont but if i will start the machine empty without any vegetables it works.Can you...
Are you sure the rubber gear is burned? have you turn the plastic lock on the bottom, so everything is thight? have you checked that the plastic O-ring is well placed?
Mar 12, 2011 | Braun K 3000 Multisystem Food Processor
When i turn on the hobart fp41 food processor nothing happens.But when i push on the contactor with a screw driver it works.Does that mean that the switch is bad or is there something wrong between the...
have you tried to replace the contactor and see if that helps at all? If there is another issue like a bad switch contact then you can still replace that becuase some of those parts are universal
Feb 28, 2011 | Hobart FP41 16 Cups Food Processor
When ice maker is on there is a clicking hoise
gear's are bad. you would be better off buying a new one.cost of service call and repair would exceed worth of unit.
Nov 15, 2009 | Food Processors
Hobart slicer 1612 need to make the product thickness ajustment knob work . It was stuck from non use . I have tried spraying with silicon spray the two shafts, but i dont undrstand the mechanism that...
Hi, I just received an older 1612 Hobart, and fixed the same problem.
First i disassembled the linkage from the bottom, then i used a propane torch to heat the rods and the aluminum castings (carefully, bring the temp till it is hot to the touch) Hammering doesnt work well so i made a piece of pine appx 1x1" with a notch to use as a pry stick. put a thin piece of plywood against the casting so you dont crack the housing, as it is thin alum.
Worked for me, take your time
Nov 13, 2009 | Hobart Food Processors
How to remove and replace a hobart slicer blade model 2712
PHIL SMITH HOW DO YOU CHANGE THE BLADE ON HOBART SLICER 1712??
Sep 09, 2009 | Hobart Food Processors
Table top grinder makes noise
these grinder usually all have a gear system see if you have any grease in the gear case or you may have motor bearing problems
Aug 08, 2009 | Food Processors
Plastic gear broke
So, rather than pay for an entire new motor and wait for two weeks forthem to get it to me, I just made a new gear/broken thing. I crazyglued the old piece back together again and used it to make a plastermold...like the way people do with their kid's hands. Then I filledthe mold with JB Weld and let it dry. After that, I drilled a hole inthe new JB weld gear so that it would fit over the metal part in thebullet(that actually spins).
Glued it on (with more jb weld) and the thing has been making my smoothies and grinding my coffee with no more issues.
Sounds complicated, but it wasn't too bad. Funny thing is, the newpiece is probably heaps stronger than the cheap plastic thing thatbroke in the first place.
Do it yourself, or e-mail me: [email protected]
I'm tired of made-to-break products and could make anyone else one of these things for around 10 bucks!
Feb 14, 2009 | As Seen On TV Magic Bullet Food Processor
Hobart Meat Slicer not working..please help!
i have a automatic holbart meat slicer and i can't get the blade to closes all the way any information? thank you:)
May 08, 2008 | Food Processors
Food Processors Logo
Top Food Processors Experts
Tom Chichester
ray gallant
ADMIN Canada
ADMIN Canada
Are you a Food Processor Expert? Answer questions, earn points and help others
