Question about Toshiba Televison & Video
SOURCE: volume button
go to start menu -> control panel -> sound and audio devices. you will find volume control. or another method is just click on the volume icon which is located at the right bottom of your windows desktop.
Posted on Jun 20, 2008
SOURCE: Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Posted on Oct 06, 2008
SOURCE: am i able to get into the menu of small orion tv without a remote
It may be possible to access the menu by holding down both volume buttons for 10 seconds. If not you probobly need the remote.
Posted on Dec 19, 2008
Try holding down both volume buttons on the front of the set. If the menu comes up use the the volume and channel buttons on the front of the set to navigate in the menu. I hope this helps you.
Posted on Mar 28, 2009
Disconnect the AC power for at least one minute to reset the clock.
Adjust the volume to the minimum using the Volume down button on the front of the unit.
Press and hold the Volume down button on the front of the unit and the 0 button on the remote control at the same time, holding them down for at least 10 seconds.
The user menu will appear with the V-Chip cursor blinking.
Press the ENTER key on the remote control and the NEW PASSWORD menu will appear.
Enter your new password.
The V-Chip is bypassed by holding the zero key on the original remote hand unit, and at the sane time holding down the volume down on the front of the TV set. This should reset the oide so you can enter a new one.
OK.
