Have a Delonghi dishwasher DEDW645S which shows E1 error code on the front ... If so, can i have the full model number of the machine.
For more click here
E1 Error
Zigzag motor error
Check/Repair
The E1 Error code appears when the needle bar is up and the sewing machine can't prepare the zigzag motor to start. Unplug the sewing machine and check the wiring connections on the zigzag motor and circuit board A. Replace the fuse on circuit board A if the fuse is blown. Replace circuit board A if it has a burned spot. Replace the zigzag motor if the fuse blows and circuit board A is okay.
Possible parts
Fuse, circuit board A, zigzag motor
JustAnswerhttps://www.justanswer.com > Appliance Repair
Jul 11, 2011 - The E1 error code indicates that a fuse is blown on the control board. The first image below shows the fuse that corresponds to the E1 error ... 1 answer · Top answer: Hello I'm Larry and thank you for using this service. I'll be helping you with your ...
Dec 22, 2009 · 1 answer
For E1 and or E2 error most likely you'll have to replace the fuse on the control board with a fuse with a higher rating. Your complete model ...
Nov. 20, 2020 - Yes, this is a system protection fault. The components attached to the main board are checked by the main board when a microwave is in use.
1 answer · Top answer: Thank you! Have a great weekend.
The E1 error code indicates that a fuse is blown on the control board. The first image below shows the fuse that corresponds to the E1 error code. NOTE: Be sure to unplug the sewing machine before you access any internal parts.Jun 10, 2008
https://www.searspartsdirect.com/diy/error-codes/sewing-machine-repair/1234596/kenmore-385-model-sewing-machine/0582
We would need to know the make and model of the treadmill as they are vastly different electronics wise. The error E1 can indicate a mismatched speed error, no belt movement when it is expected, or a faulty lower control board may also cause this. Older Matrix Fitness machines used "E" for elevation errors and "S" for speed errors but most have changed that format to E1, E2, etc..
Good Luck!
The E1 code on this dryer indicates that you have an "open" (defective) thermistor (temperature sensor). Replacing this part will likely fix your problem. What is the model number?
