Building Materials Logo
William White Posted on Feb 03, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Craftman Garage door opener and the open that is on the wall (wired) is flashing two (2) light. What does that mean?
CJ Rock
Level 3:
  • Master 4,429 Answers
  • Posted on Feb 03, 2021
CJ Rock
Master
Level 3:
Answers
4429
Questions
0
Helped
1645064
Points
15024
Safety reversing sensors wires are shorted or black white wires reversed.
Check that sensors are aligned and indicators are lit.
https://www.manualslib.com/manual/486543/Craftsman-Garage-Door-Opener.html
I have a Craftsman Keyless entry model 132B2386-6 with flashing lights, wont open. Already put in new battery still doesn't work
Why would my Keyless Entry close but not open the garage ...
www.shopyourway.com > Manage My Life > Questions
Mar 27, 2008 - I have a Craftsman Security+ Keyless Entry, P/N 139.53684 purchased with my ... However, the door will not open, but the keypad flashes as before. ... Check if there is a flashing green light on your wall control in the garage. ... The 2 remotegarage door openers won't open or close the garage door; but the ...
Craftsman garage door opener won't open or close, why ...
Hi, I have a Craftsman 1/2 HP garage door with keyless entry (P/N ... When I click theremote or the wired button, the main lights come on, the motor moves ... Five flashes means that the RPM sensors has most likely stop communicating.
LiftMaster - Support - Videos ' LiftMaster
https://www.liftmaster.com/Customer-Support/Videos
Chamberlain GroupHow to program a wireless keyless entry using your garage door opener's LEARN button. How to ... Why the LED or light on the door control is blinking and my remotecontrol is not working? Why isn't ... Why won't my door fully open? How to ...
My craftman garage door wall unit will not open the garage door. The light flashes 5 times on the unit and then repeats itself. What does this mean and how do I fix it.
check all wired connections, check all wires to insure no nail or staples have nicked them. check troubleshooting section of manual for codes possible circuit board. it is either a liftmaster or genie sold under the craftsman name
How to keep the garage door lighe on for less time
The liftmaster garage door openers manufactured after 1984 are set through the logic board from the factory with a setting of 4 1/2 minutes, That setting cannot be changed manually but you can by a premium wall control console that lets you override the logic board settings by simply pressing the light function button that allows you to shut the lights off earlier by simply pressing the button or also you can keep the lights on indefinitely by pressing the button twice! The lights will automatically go back into the 4 1/2 minute mode once the door is operated in either the up or down motion. Hope this answers your question! P.S. The premium console comes with a safety vacation lock also and can be purchased through Ebay or through Liftmaster....Remember the Liftmaster name also make the chamberlain brand and the Sears Craftman openers ...They are all cross compatible on the Premium wall console and have 2 wires on them to hook up (low voltage ) so don't worry you won,t get a shock! Just match the red wire to the terminal marked red and the white wire to the terminal marked white and screw onto your wall! Good luck .Glenn
On the sensor for the craftman garage door opener 1 is orange and the other is green and my garage door doesn't open with the remotes
Nothing wrong with the sensors. They don't work when the door is opening anyway. Only when closing. Make sure the light in the wall control is not flashing. If it is press and hold the lock button for 3 seconds.
Craftsman 53918 - 3/4 hp, belt drive garage door opener. Wall unit says safety sensors misaligned. Replaced them as suggested by manual, no fix. Does not appear to be any power from where you plug...
The main light flashing 10 times is the sign of a door sensor problem. Check to see if the small light on each sensors is lit and not flickering. If you cannot get both lights to come on your sensors or the wiring to them is bad.
1helpful
My Champion garage door opener opens by itself and the light does not come on
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
Craftman Garage Door Opener Quit Working.
It could be a bad logic board especially if you have had any electrical storms in the area. I would remove and check the logic board for burnt or missing traces on the printed circuit board.
Garage Door Opener Lights
Some craftman operator don't have that feature. Are both photo eye lights green? Feature not available. If the photo eyes are yellow and green feature should be avilable. The operator needs to have a three button wall station. With the light on the operator off press and hold the "light" button for about a minute until the light flashes.
3helpful
2answers
Basic wiring for craftman garage door opener
from left to right..
1. red. to wall button
2. white . common to wall button and white wires of sensor.
3. black. white with black strip of sensors
Top Building Materials Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Building Material Expert? Answer questions, earn points and help others
