Car Audio & Video Logo
Question about Car Audio & Video
Hi, I have a Fujitsu Ten radio for my Nissan Micra (2010). I am unable to find a code for it online and would greatly appreciate any help. The details are as follows, Nissan No. 28188AX200AU FUJITSU TEN: 123001-33300151 Serial No. ESP1C00636 QD ID: B015087
Posted by Darren Teo on
john h
    Top Expert:
  • Car Audio & ... Master
  • 28,109 Answers
Dealer with vin and proof of ownership
Posted on Apr 23, 2021
5 Related Answers
Anonymous
SOURCE: 1993 Toyota Vienta Ultima, ''Fujitsu Ten'' INF4 fault
i had the same proble. i happened to remove the changer from the boot for a few days and have a look inside but did not see anything wrong and when i put it back in it worked.
i expect it is as simple as disconnecting the changer from the head unit, turn the head unit on and off and then reconnect the changer resets the connection between the two.
Posted on Feb 21, 2010
xxxxxx xxx
  • 5047 Answers
SOURCE: 2 CONNECTORS ON THE BACK OF A TOYOTA OEM RADIO
http://www.tehnomagazin.com/Auto-radio-car-connector/TOYOTA-Car-Radio-Wiring-Connector.htm
Posted on Jul 05, 2010
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: Hey Toyota Ed, I've seen
HLP means request Help Code
When the display shows HLP (Help), you need reprogram the EEPROM, with a memory Programmer Eeproms.
I hope that helpfull to solve it.
Posted on Nov 11, 2010
RixsFixes
Radio Code Pro
  • 2200 Answers
SOURCE: how do i set the
Please try the following;
To set the time : hold down the mode button for 3 sec. use the selector knob to select the time - adjust to the desired time .
If you need to turn off demo mode : hold down the mode button for 3 sec. select demo - turn knob to off.
If you find these instructions do not work for you, please respond with the model number e.g Fujitsu Ten 1000 or 1200 and I will look at it again for you.
If the issue is resolved please leave a vote for the solution. Thanks.
Posted on Dec 07, 2010
gopakumarg43
  • 76851 Answers
SOURCE: its a fujitsu ten car
Hello
Just send me the exact model number of your Fujitsu car stereo. No serical number is needed. Only send its EXACT model number. The number you reported here is not with Fujitsu. Fujitsu website does not accept these numbers. Send it to me by FixYa. OK.
Posted on Jun 05, 2011
1helpful
Hi, I need the code of my nissan micra car radio, please. number is dw49n20486 Thanks!
There's only one way to get that code. Do this, go to the local dealer and show him the radio number, the VIN, and proof of ownership they have a special number to get these numbers. I hope this helps. Take care.
2answers
1996 nissan micra cannot input radio code
Your Nissan dealer should be able to provide you with the code.
You will need the chassis number or help you with other problems!
My nissan micra needed a new battery and now the radio wont work, i have the code but the number 2 button wont work can anyone help
You must have the radio repaired to enter the code, there is no way around the problem of the inoperable button. Next time use a battery back up, never completely power down the system. Walmart has these battery power supplies.
2answers
How to set clock on 2012 nissan micra radio
get correct manual from Nissan.
if stock radio,
the generic nissan, for 2011 will list all radios sold that year.
get one.
nissan dot com, its free.
online or at the parts counter.
Nissan micra bonnet won't open
check that the cable did not jump out behind the lever. also ,some cars have electric/ semi electric systems where you need to switch on the key to open the bonnet or the bonnet has a fuse which could be blown. check fuses.
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
