Car Audio & Video Logo
Question about XO Vision Car Audio & Video
Xo Vision XOD1752bt 6 digit password doesn't work
Posted by chuck kuhn on
ADMIN Eric
    Top Expert:
  • XO Vision Master
  • 37,282 Answers
Incorrect password typed. Type the correct password.
Posted on Feb 03, 2021
5 Related Answers
Anonymous
SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
Posted on Dec 17, 2007
Anonymous
  • 3 Answers
SOURCE: XO Vision MP3 player-problems downloading TV shows
Um hey, I have a Lyra MP3 player, I can't download videos but I have gotten music on it. When you download your music, it goes to a certain folder in your computer, it's up to you to find it. All that I did was copy/paste that to your MP3's folder. If that doesn't work I am really sorry.
Good luck,
Shannon
Posted on Jan 02, 2008
Anonymous
  • 3 Answers
SOURCE: XO Vision Xod1911
I think i had the same problem... I think the mute is on on your system...go into setup and down to default and reset everything...if your sound comes back then the problem lies within the back. You would have to un-attach the brown cord (tel-mute), After that it should work. This is the problem i had and this was the fix for me. Hopei helped
Posted on Jan 06, 2008
Anonymous
  • 216 Answers
SOURCE: XO Vision GX 1236
With solder.
[email protected]
Posted on Mar 08, 2008
Anonymous
SOURCE: no sound
You need to buy an amp adapter. SCOSCHE OEA4 4-Channel Adjustable Factory Amplifier Int. 23 bucks on ebay. You most likely have a factory amp in your car and the head unit's speaker output wires are already amped. the factory amp can't understand the audio signal.
Posted on Dec 31, 2008
4helpful
Forgotten parental password
Setup xo tablet but I dont remember doing a parent password n now its asking for one an I don't no it. Trying to get password to set wifi
Xo vision xtab factory reset
I had been trying to locate how to access the recovery options for the XO Vision XTAB tablet as well. Mine would show the XO Vision logo on start-up and then show a cursor in the upper left corner for a few seconds and then showed "ANDROID" a little further down and to the right of the upper left hand corner with a flashing cursor right behind it.
I was finally able to get into the recovery options press HOME, VOLUME UP, & POWER at the same time and hold for about 6 seconds or so. You need to let go before the XO Vision logo goes away. Wait until the logo goes away and a cursor should display in the upper left hand corner and then you'll get to the recovery / update options screen.
Use the VOLUME UP / DOWN keys to navigate the menu and then you'll press MENU to select the option. After that let it run through its processes until it completes. My attempt was unsuccessful at a factory reset and I'm still not sure how to fix it, however, you may have better luck.
1helpful
Can you text with the ematic 8gb touch screen?
Through my research I can not find any evidence that you can text on the XO Vision Ematic EM108VIDB .
It's noted feature is a FM Tuner
Is there an adaptor to receive the digital tv signals on the xo vision xt-7000? Once the tv channels changed to digital I don't have a reception with the xo vision tuner
the analog to digital converters are for home based TV systems not mobile, you can try contacting the maker of the unit and seeing if they have a solution for you
Top XO Vision Car Audio & Video Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
ray gallant
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
